crazy D Posted February 6, 2007 Share Posted February 6, 2007 i have this '81 ea81 engine in my basement(125k) and ive already took the heads off of it.....basically i was gonna tear it apart and learn junk.....tear everything apart....i think im gonna carry out the plan...but once again im a noob so its gonna be a lot of learning....but yeah i was wondering....i have no intake or anything on this thing now so im wondering do i split the block in half? and if so how do i do it?.....(there is absolutley nothing wrong with this engine i just want to tear it apart and learn) Link to comment Share on other sites More sharing options...
86BRATMAN Posted February 6, 2007 Share Posted February 6, 2007 i have this '81 ea81 engine in my basement(125k) and ive already took the heads off of it.....basically i was gonna tear it apart and learn junk.....tear everything apart....i think im gonna carry out the plan...but once again im a noob so its gonna be a lot of learning....but yeah i was wondering....i have no intake or anything on this thing now so im wondering do i split the block in half? and if so how do i do it?.....(there is absolutley nothing wrong with this engine i just want to tear it apart and learn) proper procedure would be to remove the pistons first, its got two plugs on the front, one on each half, and two on the back, again on each half, once you take them out, i think they are a m14 allen head, rotate to tdc, remove the wrist pin circlip, its a c-clip that holds the wrist pin in the journal, and slide it out from the back side, you're do this on each of the cyl's then look for the bolts that hold the block together some are visible on the other shell, some are in the coolant areas near the cyl's probably didn't explain it well, been a long time since i did this for the very same reason... best best is to get a service manual, advance sells them for $15.95 and can usually get them in a day or two, it should have the full write up of the process since i'm sure i overlooked something Link to comment Share on other sites More sharing options...
crazy D Posted February 6, 2007 Author Share Posted February 6, 2007 hmmm yeah i have know idea....remember im still a noob....ill try to fond a factory service manual... Link to comment Share on other sites More sharing options...
86BRATMAN Posted February 6, 2007 Share Posted February 6, 2007 the haynes would have everything you'd need unless you can get somebody on here to scan the fsm pages for you, i don't have a scanner or i'd post up some from my chilton's manual, just have fun with it, at least you are doing it to learn and not needing a motor rebuilt now, it'll be a good learning experiance since most all subie motors are assembled/disassembled in similar ways Link to comment Share on other sites More sharing options...
daeron Posted February 6, 2007 Share Posted February 6, 2007 http://www.finleyweb.net/JonsStuff/SubaruDocumentation/tabid/54/Default.aspx You are welcome.. :lol:Someone else here on the forum posted it a day or two ago and I figured I would bookmark it, so I could regurgitate whenever applicable. If the link belongs to you, and you don't want me forwarding traffic to it, let me know Link to comment Share on other sites More sharing options...
crazy D Posted February 6, 2007 Author Share Posted February 6, 2007 i have a haynes and htkysa and some other one...ill have fun with it...... Link to comment Share on other sites More sharing options...
