photo2001 Posted February 6, 2007 Share Posted February 6, 2007 Does anyone use the occasional can of dry gas in your Subie? It's been in the single digits here lately, and just wondering if it's a good idea. Link to comment Share on other sites More sharing options...
nipper Posted February 6, 2007 Share Posted February 6, 2007 This was just discussed. If you have ethanol in your gas its not needed. In fact if you go over the 10% mix you can hurt the fuel system. Now i use dry gas in my oil tank, which is outdoors and above ground. nipper Link to comment Share on other sites More sharing options...
Snowman Posted February 6, 2007 Share Posted February 6, 2007 At that temperature it won't matter anyway because any water in your fuel tank will likely be frozen. It's the range from about 25-45 degrees where it becomes problematic. Link to comment Share on other sites More sharing options...
photo2001 Posted February 7, 2007 Author Share Posted February 7, 2007 This was just discussed. If you have ethanol in your gas its not needed. In fact if you go over the 10% mix you can hurt the fuel system. Now i use dry gas in my oil tank, which is outdoors and above ground. nipper I did a search on 'dry gas' before posting, with no results. I think ethanol is used here in CT. Thanks for the replies! Link to comment Share on other sites More sharing options...
nipper Posted February 7, 2007 Share Posted February 7, 2007 I did a search on 'dry gas' before posting, with no results. I think ethanol is used here in CT. Thanks for the replies! Might have been on a yahoo list, im not my sharpest lately nipper Link to comment Share on other sites More sharing options...
Skip Posted February 7, 2007 Share Posted February 7, 2007 Nipper don't be so hard on yourself. You were right as usual (see below link) Ethanol and dry gas I think the search needs four letter words to work. Link to comment Share on other sites More sharing options...
OB99W Posted February 7, 2007 Share Posted February 7, 2007 [...]I think the search needs four letter words to work. I don't know, Skip -- the search function isn't that great, and I've mumbled a few four-letter words, but it doesn't seem to help. Link to comment Share on other sites More sharing options...
Olnick Posted February 8, 2007 Share Posted February 8, 2007 I've mumbled a few four-letter words, but it doesn't seem to help. That's great!!! Link to comment Share on other sites More sharing options...
86BRATMAN Posted February 8, 2007 Share Posted February 8, 2007 I don't know, Skip -- the search function isn't that great, and I've mumbled a few four-letter words, but it doesn't seem to help. The truely funny/sad part about this is that I thought the exact same thing when I read Skip's post.... Link to comment Share on other sites More sharing options...
