SakoTGrimes Posted February 6, 2007 Share Posted February 6, 2007 Went to Kragen to get new studs and a lugnut, since my threads got semi stripped when the wheel almost fell off yesterday. Took off the wheel, the big bolt, the washer and the big angled washer, but the hub doesn't want to come off it just wiggles a little. To I just need to pound it with a rubber mallet a some more or should I disconnect something else? Link to comment Share on other sites More sharing options...
Snowman Posted February 6, 2007 Share Posted February 6, 2007 Did you take the brake caliper loose? Link to comment Share on other sites More sharing options...
SakoTGrimes Posted February 6, 2007 Author Share Posted February 6, 2007 It's the rear hub, so no caliper.... right? Link to comment Share on other sites More sharing options...
Numbchux Posted February 6, 2007 Share Posted February 6, 2007 as in....brake drum? yep, the 'axle' nut is all that holds it on (I know...I had the nut fall off while I was driving....). get a rubber mallet, and go to town on it. or a regular maul. just need to shake it loose. if it's really tough, you may need a big puller. I've never had to on a subaru, but we have on other cars (caravan, Jettas, etc.) Link to comment Share on other sites More sharing options...
hooziewhatsit Posted February 6, 2007 Share Posted February 6, 2007 on the back side of the backing plate should be a small rectangular rubber piece (at least a hole where one would fit). Take it out, then use a small screwdriver to push straight in. That should release the tension on the brake shoes, and allow you to remove the hub. As the hub wears, it develops a small rim along the edge that the shoes can hang up on. So, you want to retract the shoes below this rim. -Dave Link to comment Share on other sites More sharing options...
SakoTGrimes Posted February 6, 2007 Author Share Posted February 6, 2007 I guess this will have to wait til AZ... the net went down for a while and I put everything back together... I have 4 lugnuts on tight now so I'm sure I'll be fine. Thanks, see yas later Link to comment Share on other sites More sharing options...
desertsubaru Posted February 7, 2007 Share Posted February 7, 2007 SakoTGrimes said: I guess this will have to wait til AZ... the net went down for a while and I put everything back together... I have 4 lugnuts on tight now so I'm sure I'll be fine. Thanks, see yas later You should be fine if they got tight. Every time you stop check them:cool: Good luck keep us informed. When you do get time make sure you get to sedona it is A MUST SEE. I lived there for 3 years and loved it. The bad part is that it was to hot for me to do my trade of a pipe layer. Link to comment Share on other sites More sharing options...
Phizinza Posted February 7, 2007 Share Posted February 7, 2007 Have you tried putting the wheel back on and getting under the car, then kicking the wheel while under the car.. You can get a pretty bit hit with your foot. Link to comment Share on other sites More sharing options...
86BRATMAN Posted February 9, 2007 Share Posted February 9, 2007 desertsubaru said: The bad part is that it was to hot for me to do my trade of a pipe layer. hmmmm, should i make a bad joke at your expense... Link to comment Share on other sites More sharing options...
misledxcracker Posted February 11, 2007 Share Posted February 11, 2007 it doesnt really get that hot in sedona... Link to comment Share on other sites More sharing options...
