Clunk coming from my steering gear
Guest subu luvr
many clunks can disguise themselves....
frequently balljoints, or top bearings of the strut can make sounds
when worn out..
also, i think the rack has an adjustment, most do, which might
solve that clunk, but i would have a real good look at the other junk under there too..
Guest subu luvr
DOH
sorry, other parts include,
ball joints,
inner and outer tie rod ends,
strut top bearing,
the u-joint on the steering column also sometimes croaks
really helps if you find someone to oscillate the wheel while you
look/feel for the loose part(s).
