ivantruckman Posted February 8, 2007 Share Posted February 8, 2007 hi all. im trying to find out how to read codes on an 86 gl, ecu light is on, the car was running slugish, i repaired the wire to the o2 sensor, it runs good now , but the ecu light is still on, thanks in advance, Ivan Link to comment Share on other sites More sharing options...
misledxcracker Posted February 8, 2007 Share Posted February 8, 2007 remove the panel under the dash, where the fuse box is... the silver box with the red light is your ECU. search around, its actually pretty easy to read the codes and "decipher" them Link to comment Share on other sites More sharing options...
mikeshoup Posted February 8, 2007 Share Posted February 8, 2007 If the ECS light is on, the light on the ECU will be blinking. Remove the lower panel, there should be a light on the computer on the front of it. http://www.ultimatesubaru.org/forum/showthread.php?t=49918 Lists the codes and what they mean. Link to comment Share on other sites More sharing options...
ivantruckman Posted February 8, 2007 Author Share Posted February 8, 2007 Whoop Dare It Is, you guys rock, thanks Link to comment Share on other sites More sharing options...
ivantruckman Posted February 8, 2007 Author Share Posted February 8, 2007 i didnt relize how the o2 sensor could affect a carburator, Link to comment Share on other sites More sharing options...
ivantruckman Posted February 8, 2007 Author Share Posted February 8, 2007 what the heck is ignition pulse system, it keeps flashing "dash dot pause" i think this is elevin, the manual says ignition pulse system Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 8, 2007 Share Posted February 8, 2007 http://www.ultimatesubaru.org/forum/...ad.php?t=49918 Ignition Pulse System... I´m not Sure... it´s Somethin´ about the Crank Angle Sensor. Look Here too: http://www.obd-codes.com/trouble_codes/subaru/1983-1988-subaru-carbureted.php Link to comment Share on other sites More sharing options...
misledxcracker Posted February 8, 2007 Share Posted February 8, 2007 11 is fine, I believe. But dont quote me on that... Link to comment Share on other sites More sharing options...
mikeshoup Posted February 8, 2007 Share Posted February 8, 2007 11 is fine, I believe. But dont quote me on that... If the ECS light is on while the engine is running, it is not okay. Link to comment Share on other sites More sharing options...
misledxcracker Posted February 9, 2007 Share Posted February 9, 2007 I said "dont quote me on that" for a reason. Link to comment Share on other sites More sharing options...
