quick question re: shifter
The pushbuttons may be different. Look on the side and see if there is something like a pin holding it in. You may have to punch it out with a punch of the appropriate size.
Mikeshoup is right. On the standard tranny, it's lefty loosy (simply unscrew and remove the knob, pulling it away from the rubberized boot top). On the pushbuttons, there is apparently a pin that must be removed with a punch.
There is a small roll pin that goes through from the left side to the right.
Be carefull, the wiring that goes to the switch is embedded in the boot, so just leave the knob flopping while you remove the boot.
noticed the wiring, did plan to be wary of it, found the pin (not that was much of a challenge) and cannot get the damn pin out. with anything.
you'll need a straight punch that is exactly the same size as the roll pin, or just slightly smaller, using a tapered punch usually expands the pin making it almost imposible to remove without damaging it
a decent set of pin punches are invaluable.
they look something like this:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93111
you should be able to get a similar set locally at your favorite tool outlet.
