Goatboy Posted November 20, 2003 Share Posted November 20, 2003 Is it normal to hear water, or whatever it is, running through the heater core? I hear it gurgeling when I am at idle. I assume it is doing it all the time but I just can't hear it over the engine and air noise. But is this normal? Do any of you experience this as well? --GoatBoy Link to comment Share on other sites More sharing options...
Scrub2k Posted November 20, 2003 Share Posted November 20, 2003 My Car did the Same Thing When i Had an Airbubble in the coolant, park your car on a slight up hill and run it till its warm with the radiator cap off, squeeze the upper radiator hose and the air should work its way out, this is how i do it, maybe someone else around here has another way Link to comment Share on other sites More sharing options...
Goatboy Posted November 20, 2003 Author Share Posted November 20, 2003 That makes sense. It sure is an interesting sound!! Link to comment Share on other sites More sharing options...
torxxx Posted November 21, 2003 Share Posted November 21, 2003 Yeah, I gotta do the same thing tommorow.. When you do it, the trick is to SLOWLY pour in antifreeze.. Make sure your heater fan is on full blast and you have it on hot air Vent... Link to comment Share on other sites More sharing options...
