You can go plenty bigger than that. Stock size for your vehicle is 175/70-14. Punch those numbers into the Miata tire size calculator, then play with the numbers that you would like to fit on your car.
http://www.miata.net/garage/tirecalc.html
You don't want to go smaller then OEM size if possible as it will leave a larger gap above your wheel and look kind of funny. If possible, find the exact size or a tiny bit larger.
195/50-16 or 195/45-17 would probably be your best bet, but may be tough tire sizes to find.
