dancing distutator
so here i am 100 miles from home[at my inlaws]and my dist.is jumpimg all over beond 3000rmp's its a 86 1800 overhead cam ,,,carberated 4 dr.4x4.in the past if any, ea81 dist did that i just oiled the dist bearings and bam its fixed.so i oiled mine and its still jumping around and craping out in higher rpms.any ideas? i'm having my daughter bring down a different distributor just as a stab in the dark.any thoughts would be cool.thanks,todd the old guy:confused:
so i limped it home.my daughter had brought down a "vented"dist.with 2 lines on the vacume advance.i didn't want to screw things up so i chanced it.i looked around my place and i have a few like that,vented and 2 lines on vacume advance.are they interchangable with non vented with one line on the vacume advance? any advice would be cool.thanks todd
Yes they are interchangable. The bit you are refering to as a "vent" is not. It's a retard port for the feedback carb equipped EA82's. Leave it open (not capped) and just use the inner port as that one is the advance.
