anyone ever make a Demon carb work on a soob?
The Weber is rated at 325cfm, but it is what is called a progressive carburator, meaning it does not open all at once. This is done so that you do not have driveability problems. For a carb to operate effeciently/properly there has to be some vacuum in the intake manifold (or the intake manifold must be at a lower pressure than the surrounding air), this does two things, it keeps air moving in the right direction and it causes the fuel to be drawn into the engine. If you install too big a carb on an engine and open it up the low pressure area (in the intake manafold) dissappears and no fuel is drawn in.
Yeah i found the 6 pack setup
http://www.barrygrant.com/news/articles/products/product_004.aspx
It seems that they only offer that carb with that 6 pack manifold but that seems odd. I bet if someone really wanted just the center carb with electric choke it could be had. 250 CFM sounds about right for our sooby engines. Only thing i wonder is if that is any bigger than a stock hitachi. Anyone know?
I'm working on a custom intake for a single Holley 2bbl pattern, using a Motorcraft 2150 carb at 285cfm. They produced those carbs from 220cfm up to 450cfm, and I have a few to choose from.
A custom intake will be needed, though, since the carb is rotated 90º.
The Weber and stock Hitachi are vacuum secondary carbs, while the Motorcraft, Holley, and Demon are straight 2BBL carbs, with both throttle blades opening at the same time.
