Climate Control Slider Issue
hey my climate control temperature slider, as stated above, is sticking,
it feels like if I tug on it that it will break something on the inside,
I already know that Im taking it apart to fix this but, I would like some info on things to be weary about when dissasembling this piece and how to do it.
hmm... assuming the cable itself isn't frozen in it's sleeve, and everything on the flapper side is still fine, it may be that the cable right at the slider has a kink in it, and doesn't want to go down it's sleave. Once you get to where you can see the side of the temp controls, you'll see a pinch joint that grabs the sleave. You may just have to loosen that and pull the sleave farther up.
Won't know until you dig into it though :-\
