SakoTGrimes Posted February 14, 2007 Share Posted February 14, 2007 It's not like I need extra stopping power or anything, but I had new brake drums priced today, and I guess they're getting rare, $135 each. Gen-1 and 3 cars can be swapped to rear disc with parts from a turbo car, can a Gen-1 accept parts from a turbo car, or combination of N/A Gen-1/2 and turbo parts? Having 4 wheel discs would be sweeeet and look cool too Link to comment Share on other sites More sharing options...
carfreak85 Posted February 14, 2007 Share Posted February 14, 2007 There is a fair amount of grinding necessary on the caliper mounting bracket IIRC. A friend of mine attempted installing a set on his 1980 BRAT, but gave up before finishing. Thats not to say that it can't or hasn't been done (It has). Now that we have the 75 wagon, I might give it a try. Does anyone know the diameter of the brake master cylinder for a 75 4wd wagon? Link to comment Share on other sites More sharing options...
75subie Posted February 14, 2007 Share Posted February 14, 2007 look up zefy's gen 1 rear disc write up. he did it fairly easilly and liked the results. Link to comment Share on other sites More sharing options...
75subie Posted February 14, 2007 Share Posted February 14, 2007 http://www.ultimatesubaru.org/forum/showthread.php?t=53479 Link to comment Share on other sites More sharing options...
Hodaka Rider Posted February 14, 2007 Share Posted February 14, 2007 I happened to stop by the day he and Jim were doing that. It was dark out by that point, and the air was fairly blue. It was WAY more work than they thought it would be at the outset, but they got it done and it worked fine! Link to comment Share on other sites More sharing options...
Subieguy Posted February 14, 2007 Share Posted February 14, 2007 I did it on my 78 Brat. Quite a bit of grinding on the backing plate and I had to grind a pretty serious notch into the trailing arm itself. That was to clear one of the caliper bolts. The three bolts on the backing plate line right up when you have enough ground away. I am really happy with how it turned out and how it looks. Looks cool having 4 wheel discs on a gen 1 Brat:headbang: . The thing I still need to do is get longer brake lines to go to the calipers. The originals are a little short for the disc setup so the don't run in the same location as original. They are just kind of free and floating around back there. Would be a problem if I actually drove it very much. I will get around to taking care of that one of these days. Link to comment Share on other sites More sharing options...
kiwi subbie Posted February 18, 2007 Share Posted February 18, 2007 i though about doin that on my 1400 if it would work Link to comment Share on other sites More sharing options...
ThreeEyedBandit Posted February 19, 2007 Share Posted February 19, 2007 On my old 79 wagon, i just re-clocked the backing plate by drilling three new holes in it. So that everything would clear the trailing arm. Matt Link to comment Share on other sites More sharing options...
maudsland Posted February 23, 2007 Share Posted February 23, 2007 Back in 1980 when i was picking up one of my FF1's i came across a fellow who had a factory subaru GSR rally car from 1974, while i was drooling over it i noticed that it had disc brakes on the back of it, that was the first and only time i had ever come across it, also i saw some intersting bits that he had in his shed Thierry Link to comment Share on other sites More sharing options...
moosens Posted February 23, 2007 Share Posted February 23, 2007 Back in 1980 when i was picking up one of my FF1's i came across a fellow who had a factory subaru GSR rally car from 1974, while i was drooling over it i noticed that it had disc brakes on the back of it, that was the first and only time i had ever come across it, also i saw some intersting bits that he had in his shedThierry more!!!! we want more information!!!! Find him,rope and tie him,whatever it takes.... Link to comment Share on other sites More sharing options...
maudsland Posted February 23, 2007 Share Posted February 23, 2007 if you do a search somehow and find rallying in australia early 70's any pictures you see is most probably of that car, they were a factory team but left the cars behind, i haven't crossed path with that guy for over 20yrs Link to comment Share on other sites More sharing options...
maudsland Posted February 23, 2007 Share Posted February 23, 2007 If you can get a hold of a book " Subaru the innovator downunder" there is a picture of the car there, i am still trying to find a link at the moment Link to comment Share on other sites More sharing options...
moosens Posted February 23, 2007 Share Posted February 23, 2007 thanks,but it's not something I'm about to do right now. Link to comment Share on other sites More sharing options...
Zefy Posted February 27, 2007 Share Posted February 27, 2007 ya i've done the rear disc conversion... harder then i thought, but not impossibly difficult... i would recommend bending the end of the trailing arm vs. grinding it down... help keep more material there making it a little stronger... it looks really sweet since you're front and rear rotors are actually the same size...:-p Link to comment Share on other sites More sharing options...
