[HTi]Dain Posted February 17, 2007 Share Posted February 17, 2007 Yep, so I found two cracks on the Block surface they are both on the right side of the engine (from driver's seat, or back of motor). The one I am most concerned about is between the number 3 (I believe, correct me if I'm wrong) and the main water-jacket. It doesn't look related to the motor freezing, but more like a crack from heat. I'm not really sure. But I was having a water consumption problem prior to the tear down (and the freeze--no coolant=frozen engine=cracked head:-\ ). Also, there was a very small crack between the two water-jackets in the front of the motor (on the right-hand side of the picture). So is the block shot? Or will the running motor not be noticably affected by these cracks? You can barely make out the crack in this one. It's difficult to get a better picture of it Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 17, 2007 Share Posted February 17, 2007 I would run it. Might eventually contribute to gasket failure at that point, but should last a long time before that happens. As long as you can't catch a fingernail in it, I wouldn't worry about it. It's probably from a severe overheat at some time in the past. GD Quote Link to comment Share on other sites More sharing options...
nipper Posted February 18, 2007 Share Posted February 18, 2007 Well there is only one (make it two) ways to find out. Do a leakdown test on the cylinders (requires least amount of assmbly) and see if it holds pressure. I really dont like the one in the cylinder at all, comsidering that can cause a hot spot and pre ignition. I would just find a short block. nipper Quote Link to comment Share on other sites More sharing options...
Nug Posted February 18, 2007 Share Posted February 18, 2007 Considering that the cylinder is a steel liner, I'd run it. Sure, it looks scary, and there may be an eventual failure. But if the coolant temp is held in check, then I doubt there will ever be a problem if driven normally. Quote Link to comment Share on other sites More sharing options...
[HTi]Dain Posted February 18, 2007 Author Share Posted February 18, 2007 Normal? What would "normal driving" be for a Subaru:confused: It is my daily driver, but I often take it off-road: sand, mud, gravel. But the sand is the real killer on these cars, I think. It'll get pretty hot when in the sand. And I think this crack (plus a partially clogged radiator) can account for my water consumption. I'll check around for a short block. Quote Link to comment Share on other sites More sharing options...
Turbone Posted February 18, 2007 Share Posted February 18, 2007 I would chuck it. Aluminum contracts and expands with heat. That crack could get bigger. EA81 blocks are plentiful here in the PNW. Quote Link to comment Share on other sites More sharing options...
Nug Posted February 19, 2007 Share Posted February 19, 2007 Dain'] Normal? I knew someone was gonna call me on that! Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted February 19, 2007 Share Posted February 19, 2007 Dain']Yep' date=' so I found two cracks on the Block surface they are both on the left side of the engine (from driver's seat, or back of motor). The one I am most concerned about is between the number 3 (I believe, correct me if I'm wrong) and the main water-jacket. It doesn't look related to the motor freezing, but more like a crack from heat. I'm not really sure. But I was having a water consumption problem prior to the tear down (and the freeze--no coolant=frozen engine=cracked head:-\ ). Also, there was a very small crack between the two water-jackets in the front of the motor (on the right-hand side of the picture). So is the block shot? Or will the running motor not be noticably affected by these cracks? [img']http://i138.photobucket.com/albums/q261/htidain/Blockcracks005.jpg[/img] Isn't the the right side, as seen from the driver's seat, look at the bell housing. Quote Link to comment Share on other sites More sharing options...
daeron Posted February 19, 2007 Share Posted February 19, 2007 thats an ea81 block??? where do the pushrods go???? Quote Link to comment Share on other sites More sharing options...
[HTi]Dain Posted February 19, 2007 Author Share Posted February 19, 2007 thats an ea81 block??? where do the pushrods go???? Just below the cylinder there. The lifters sit inside the block. Quote Link to comment Share on other sites More sharing options...
daeron Posted February 19, 2007 Share Posted February 19, 2007 Dain']Just below the cylinder there. The lifters sit inside the block. That slit on the bottom left corner, between the stud and that hole about the size of a finger? I couldnt tell which were pushrod channels and which were coolant or oil passages. (terminology?) At first, I had thought it was an OHC motor, thats all...... Gee, who has never had his engine apart (yet)? Quote Link to comment Share on other sites More sharing options...
