Phizinza Posted February 19, 2007 Share Posted February 19, 2007 This little do-whats-it was unplugged when I got the 89 Subaru Liberty (Legacy) and the car ran fine with it unplugged.. It has two vacuum hoses connected to it. One from just after the throttle body, and one that goes to the charcol canister, through a metal pipe beside the tank vent hose. http://offroadingsubarus.com/images/temp/what_the_hell_is_this1.jpg http://offroadingsubarus.com/images/temp/what_the_hell_is_this2.jpg What does it do? Can I remove it? Should I plug it back in? Thanks Link to comment Share on other sites More sharing options...
the_postie Posted February 19, 2007 Share Posted February 19, 2007 purge control solnoid.yeah you can dissconnect ,stick a resistor in the wiring so no fault codes and crap runnining and plug the hoses.But if its working leave it in there its there for a reason. Link to comment Share on other sites More sharing options...
Phizinza Posted February 21, 2007 Author Share Posted February 21, 2007 Ok. I'm going to try the engine without it. All it can really do is close off the pipe to the canister and that pipe on most other cars I've seen is normally just a open anyhow. I know the whole "if it's there, it's there for a reason" thing. But I really just don't believe that anymore. There are so many stupid useless things in cars that I have seen it just isn't funny. If it doesn't run right, I'll try it with it plugged in. We'll go from there. Link to comment Share on other sites More sharing options...
the_postie Posted February 21, 2007 Share Posted February 21, 2007 you've got to put a resister,can't remember the ohms, in the wiring that goes to the ecu it'll fault code and run a bit rough.What it does is open that line up from the canister back to the throttle body to purge the vapor/fuel thats in the canister.I know guys that have run without it.You'll need it if you want to get your conversion complianced.Might smell a bit fuelly. Link to comment Share on other sites More sharing options...
Phizinza Posted February 21, 2007 Author Share Posted February 21, 2007 the_postie said: you've got to put a resister,can't remember the ohms, in the wiring that goes to the ecu it'll fault code and run a bit rough. That's interesting. I drove the Liberty it came out of just before I pulled the engine and it was fine, not rough at all. Had plenty of go as well. Link to comment Share on other sites More sharing options...
the_postie Posted February 22, 2007 Share Posted February 22, 2007 did the check engine light come on? Link to comment Share on other sites More sharing options...
Phizinza Posted February 22, 2007 Author Share Posted February 22, 2007 the_postie said: did the check engine light come on? Nope... unless it is blown, and does not light.. Link to comment Share on other sites More sharing options...
