ecky Posted February 19, 2007 Share Posted February 19, 2007 I have noticed that there is a few companys out there that make all sorts of goodies for the Ea81, but why doesn't anybody make goodies for the Ea71? Link to comment Share on other sites More sharing options...
mikeshoup Posted February 19, 2007 Share Posted February 19, 2007 Probably because the majority of the after market for the EA81 is for aircraft use. Why use an EA71 when the EA81s are more common and make more power. Places like ram performance could probably get you performance parts for EA71s. Link to comment Share on other sites More sharing options...
Seahag1978 Posted February 19, 2007 Share Posted February 19, 2007 They did make performance parts, they're called hills... in the downward direction only It is, what it is. Stable, steady and reliable, it will also keep you from getting a ticket when used as directed Link to comment Share on other sites More sharing options...
crazy D Posted February 19, 2007 Share Posted February 19, 2007 They did make performance parts, they're called hills... in the downward direction only It is, what it is. Stable, steady and reliable, it will also keep you from getting a ticket when used as directed Link to comment Share on other sites More sharing options...
ecky Posted February 20, 2007 Author Share Posted February 20, 2007 It is, what it is. Stable, steady and reliable, it will also keep you from getting a ticket when used as directed Ture, I guess I will just have to live with it Link to comment Share on other sites More sharing options...
RenaissanceMan Posted February 22, 2007 Share Posted February 22, 2007 once I get past the other millions of projects, I do plan to build a TBI setup for the EA71... Delta Camshaft does make a few cams for the EA71 btw. -Mike Link to comment Share on other sites More sharing options...
970subaru Posted February 23, 2007 Share Posted February 23, 2007 turbo or supercharger setup could be built and theres always nitrous Link to comment Share on other sites More sharing options...
carfreak85 Posted February 26, 2007 Share Posted February 26, 2007 Because the EA71 and EA81 are so similar, the discussion we recetly had about the latter engine I think applies. The tiny intake/exhaust ports and the fact that they are siameased means the engine has little ability to breath. Forced induction solves this problem, but why sink the money into an EA71 when the EA81, EA81T, EA82, EA82T, EJ18, EJ22, EJ25 and all EJT engines are superior designs that with some modification will fit into your chassis Link to comment Share on other sites More sharing options...
Subaru_Mechanic Posted March 2, 2007 Share Posted March 2, 2007 dude if you have a friend that owns a shop.. get the parts made... new lightweight everything. cool air intake high flow turbo and exhaust.. you can make stuff you just gotta have $500 to play with... make it happen... Link to comment Share on other sites More sharing options...
