rallynutdon Posted February 19, 2007 Share Posted February 19, 2007 95 Impreza, 2.2, 5 speed. Cable and lever move okay. But clutch won't completely disengage. Can't get it into gear while engine is running and clutch pedal is pushed in. Goes into gear fine when engine shut off. Play in lever seems fine with clutch pedal out. What could have bent/broke/shifted? TIA. Link to comment Share on other sites More sharing options...
Skip Posted February 19, 2007 Share Posted February 19, 2007 do you have the cable adjusted so the clutch pedal has about 1/2 inch of free play? Link to comment Share on other sites More sharing options...
Skip Posted February 19, 2007 Share Posted February 19, 2007 Have you checked the tranny fluid level, dry syncros not allowing gear engagement? There have been reports of throw out bearing clips breaking, don't know if that would cause no dis-engagement. Link to comment Share on other sites More sharing options...
Skip Posted February 19, 2007 Share Posted February 19, 2007 Try this put the car in 1st gear and then start the engine with the pedal depressed does the car lurch forward? has it been sitting and somehow the clutch disc is frozen to the flywheel? Link to comment Share on other sites More sharing options...
rallynutdon Posted February 19, 2007 Author Share Posted February 19, 2007 Car was driven 5 miles this morning before this happened. Yes, with clutch pedal in and car in 1st gear, when you start the engine it moves forward. There's not 1/2 inch play, but IMHO there's enough. I don't have any tools here at work to try to adjust it further. I didn't check fluid level but I'd bet alot of money it's okay. Drove another 8 miles after this happened with no noises. Slipped the clutch really bad in 3rd at one point to get it moving then drove in 3rd the rest of the way (1 mile). Broken clip shouldn't cause this unless tab of throw out bearing is jammed between fork and pressure plate fingers! Link to comment Share on other sites More sharing options...
Skip Posted February 19, 2007 Share Posted February 19, 2007 thanks for the rest of the story. Broken clip shouldn't cause this unless tab of throw out bearing is jammed between fork and pressure plate fingers! or it allowed the release fork to slip off the pivot point good luck Link to comment Share on other sites More sharing options...
ScoobySchmitty Posted February 19, 2007 Share Posted February 19, 2007 Uh...another thing you might want to try if it is the cable clutch...make sure the fork hasn't completely BROKEN IN HALF at the pivot point. I had this happen on my 91 before...shifting really hard, had to rev-shift it most of the way home when it broke. I didn't know it broke in half until I pulled the transmission! Weird problem, easy (yet time consuming) fix and I threw in a new clutch while I was at it. Link to comment Share on other sites More sharing options...
rallynutdon Posted February 19, 2007 Author Share Posted February 19, 2007 I was thinking about that. But then I would think there'd be very little resistance when you pushed the clutch in. Link to comment Share on other sites More sharing options...
rallynutdon Posted February 19, 2007 Author Share Posted February 19, 2007 Just checked the fluid. It's okay. Finally got the adjusting nuts lose. Adjust it both directions to the extreme and it made no difference. Time for the trailer! Link to comment Share on other sites More sharing options...
nipper Posted February 19, 2007 Share Posted February 19, 2007 Can be a few things, starting with a stretched out clutch cable, broken parts (fork), broken throwout bearing clips etc etc How many miles on this car? When was the last time the clutch was done nipper Link to comment Share on other sites More sharing options...
rallynutdon Posted February 19, 2007 Author Share Posted February 19, 2007 Not a stretched cable. Mileage is not important. Engine, transmission and clutch just put in (all used) and car has been driven about 1000 miles since then with no issues. It will have to come apart to physically see whats wrong. Possibly once I have it home and can take the boot off I may be able to see down inside and see something. But regardless, it will have to come apart. Thanks everybody for all the suggestions. I'll update this when I find out what it is (may not be till this weekend). Link to comment Share on other sites More sharing options...
RallyKeith Posted February 26, 2007 Share Posted February 26, 2007 See the attached image of the disk. Link to comment Share on other sites More sharing options...
nipper Posted February 26, 2007 Share Posted February 26, 2007 That will do it nipper Link to comment Share on other sites More sharing options...
SuBrat84 Posted February 26, 2007 Share Posted February 26, 2007 I was just going to say.. sounds like one of the springs on the used clutch disc probably broke! See the attached image of the disk. Link to comment Share on other sites More sharing options...
rallynutdon Posted February 26, 2007 Author Share Posted February 26, 2007 But I don't understand the mechanics of how that prevented the clutch from disengaging completely? There were no signs of any pieces being jammed in anywhere, no marks on the pressure plate, disc or flywheel. Everything looked normal until I took the pressure plate off. One thing, I never did find the piece of metal that was broken off the disc. It must have fallen out the slot in that plate below the housing. Link to comment Share on other sites More sharing options...
