skishop69 Posted February 27, 2007 Share Posted February 27, 2007 I did a search and there was just too much to go through. The ignitor went bad on the 87.5 (along with several other things that have been replaced) and I want to know where to get a new one or if it can be bypassed. This 'new' car is beginning to p*ss me off !!! Quote Link to comment Share on other sites More sharing options...
suberdave Posted February 27, 2007 Share Posted February 27, 2007 what do you mean Ignitor? do you mean coil or something in ign. system. i dont think the EA82 has an ignitor like many other import cars. if i know what you need i probably have one you can have for cheep... -=Suberdave=- http://www.suberdave.com Quote Link to comment Share on other sites More sharing options...
Turbone Posted February 27, 2007 Share Posted February 27, 2007 Maybe he means the piece in the disty. Quote Link to comment Share on other sites More sharing options...
skishop69 Posted February 27, 2007 Author Share Posted February 27, 2007 The ignitor is a little transistor that is attached to the coil bracket. The ECU sends the signal to it/ through it to fire the coil. I've done the cleaning routine with no change. I drove it back from Olympia before I tore it down for head work and rings. No it runs for about 10 min and dies or dies immediately if you rev it up. When it dies, I have no spark and the trigger line for the coil glows dim (with test light) with no pulses. When running it is bright and pulses. Usually when a transistor goes into cascade failure, this is how it acts. I saw in one of the threads, that someone had used a late 70's GM igntion module to replace it. I'll have to go check schematics, but it should be possible and not too hard. If I can find one new, I'd like to go that route, or some kind of bypass. Quote Link to comment Share on other sites More sharing options...
