Project Progress Update!
I have been getting tons of emails from you guys woundering what happened to me and the project! :0
Well I have been enrolled in College full time and working 2 jobs so I have been very busy to say the least but that doesnt stop the mods for the GL10 :)
Here's the mod list as of today :
EA82T Shortblock from SOA (12,000miles on it still going strong)
EA82T Gen3 Cylinder Heads w/mild port and polish
Subaru OEM Headgaskets
NEW Subaru OEM Head Bolts
Changed to Stock EA82T Camshafts
Greddy E-Manage Ultimate Engine Managment
Greddy Pressure/MAP Sensor Conversion
NGK AFX Wideband O2 Monitor System
Bosch Spark Plugs (1-heat range colder than stock)
NAPA Premium HP Spark Plug Wires
Nissan 280ZX Turbo 265cc Fuel Injectors
Walbro 255lph In-Line Fuel Pump
MSD Blaster 2 Ignition System
Modified EA82T Header w/TD04 Flange
InVida 3-inch Catless Turbo Downpipe
2.25inch Streight Pipe Exhaust from the downpipe to the rear bumper (no cats)
TD04-13T Turbo@15psi
Perrin Manual Boost Controller
4-row Huge Top Mount Intercooler w/HKS SSVQ
Converted Air Struts to Coil Springs/Struts (KYB GR2's)
5-speed Dual Range 3.90 Tranny
XT6 Clutch Kit
2-row Heavy Duty Radiator
180F Thermostat
Custom Dual Electric Fan Conversion (Fully Controlled by E-Manage Ultimate)
Electronic Rev Limiter @ 6500rpm thanks to E-Manage Ultimate :headbang:
Launch Control @ 3500rpm and spools up 5psi gets me off the line thanks to E-Manage Ultimate
Autotune via Wideband System Interfaced to the E-Manage to automatically shoot for my inputted Target Air Fuel Ratio's in the maps for perfect day to day driving given any condition changes with weather or altitude
Now for the Interior :
Alpine 9856 Mp3 Headunit w/Full Speed IPOD Input
Apple 20gig Video IPOD Interfaced into the Alpine Headunit
(4)-Alpine 6.5" TypeS Speakers
12-inch MTX Thunder 5500 Subwoofer in Subzero Sealed Enclosure
JBL 4-channel Amp running the TypeS's
Scosche 2-channel 600watt Amp driving the MTX Sub
CRX Autometer 2-Gauge Piller POD
Autometer Vac/Boost Gauge
Autometer Mech. Oil Pressure Gauge
OBX Racing Shift Knob :cool:
2004 WRX Black Rubber Floor Mats:clap:
OK now for the TODO/Waiting list :
VF39 Turbo Upgrade -or- TD05H 16g Turbo Upgrade (cant decide)
Custom Venom 360cc Fuel Injectors (Being made right now, will be here in 1.5weeks)
AEM Fuel Pressure Regulator (waiting to be installed)
Greddy E-01 Electronic Boost Controller/E-Manage Ultimate Controller Interface unit (Comming soon)
XT6 5-speed Full Time AWD Tranny (waiting to be installed)
XT6 Flywheel (Resurfaced and waiting to be installed)
SPEC Custom Stage-3 6-puck Clutch Kit (in the mail)
FULL XT6 5-lug Conversion (Waiting to be installed)
XT6 Sway Bars (Waiting to be installed)
15-inch American Racing Alloy Wheels/Tires from the XT6 Donar Car (Waiting to be installed)
Megan Racing FULL Coilover Suspension Kit (Comming soon)
3.90 LSD Rear Differential (Comming soon)
17" Rota Group-A Bronze Wheels w/Toyo Proxes T1R 205/40/17 tires (Comming soon)
*FEW* Ok i'm tired of typing now, now on to the questions!
As you can see im trying to build the Ultimate EA82 and go where no one has gone before and some deem not possible! WOOHOO :)
  carfreak85 said:
My goal only three years newer and a sedan instead of a wagon. Friggin' SWEET man! How was the e-manage to install/tune?
The E-Manage Ultimate is a dream come true for the EA82, its working excellent and installation isnt bad at all! Everything works perfectly!
I wish I installed it a long time ago, would of saved going threw motors to find out that the stock EA82 Computer and Fuel System are ************ and cant take even turning up the boost slightly!
Now at WOT i enjoy 11.0-11.5 AFR's all day long to 6500rpm gotta love that.
Nice setup, man! good to see somebody willing to spend the money on all that tech for the soobie. :headbang: sounds like keeping the engine well bathed in fuel might help avoid any potential turbo engine longevity issues. Thats normally the case :rolleyes:
you are running stock CR for the ea82T, though, right?
for some reason I had falsely fallen under the impression that you were building a high comp turbo..
And extra congratulations paying for (and building, for that matter) ALL OF THAT while working and going to school!!!! *I* couldn't pull all that off by a long shot.
  jeffast said:
adds items to x-mas list
Except I'm going to use MegaSquirt'N'Spark. There are a bunch of guys up here who run it. My best friend has it on his SC Miata and another two have it on built/turbo golfs. I'm supprised you could afford the E-manage on a student budget.:slobber: Oh, wait the two jobs thing, hahaha!!:clap:
  thatswhatshesaid said:
Has this car been dyno'ed?
Car has been dyno'd a few times but not with the current state of good tune.
The last dyno showed a 14.3sec 1/4mile time (mustang dyno) 166whp and nearly 200wtq at 9psi of boost with the AFR bouncing around 13.8 to 14.5:1 at WOT, since then I have fixed the problem with the Walbro 255 Fuel Pump and have yet to make another pull with 15psi.
Should be interesting.
The Clutch and AWD Tranny Swap is happening this weekend. I'll keep you posted.
  Hodaka Rider said:
So the question remains: why has no-one O-ringed one of these yet?
someone did, I remember a awesome sedan with O-ringed turbo block, but the main thing keeping people from doing it is money I guess, as is with a lot of things ;)
@ steveman09: :slobber: awesome job, extremely jealous of your work and dedication, I may have to copy your work some time ;)
  PoorManzImpreza said:
detonation and over heating contribute the most to blown headgaskets.. and age as well..
friggin awesome job! We need more PICS please!:burnout: :burnout:
Oh and why did you go back to stock ea82t camshafts?
probably for driveability, for most turbo cars, stock cams are the best, you can get "Hotter" cams for it, but you'll need every little bit of torque you can get out of the cams to overcome the turbo lag :P
torque cams on the other hand don't breathe enough top-end, so midway is best, and those are the stockers :wink:
Nice to know that someone did do it.
  Quote
Doesn't look like 'low budget' really describes this build. Although, I suppose it's obviously not a 'blank cheque' project either.
  Numbchux said:
now, get some beefy rods made for it....and see what it'll really do :banana:
I beleive that the stock rods are plenty strong for a mild turbo engine. Once someone builds a RELIABLE 200WHP engine, then mayb ecryo treat the rods, but most turbo engines have rods that will handle more that 1.5 times the factory output at least.
The clutch and injectors are here! :
Clutch is a Stage 3 from Spec and had to be built.
Injectors were custom made from Venom, thew a connection I have.
If ANYONE wants any of the parts I used for the build let me know and I can get you whatever you need!
There is hope for the ea82 you just have to search and dig deep and know the right people ;)
