Howdy all, I am upping the boost on my SOHC EJ22 and will be using the fuel system, does anyone know if the is an injector of a larger flow rate which will bolt right in place of the standard ones?
What size are the standard ones?
red topped I think.
Are nissan ones the same style?
Cheers Matt
I dont know what those are but I do know that WRX injectors will work. and they have a higher flow than normal, I wana say 600, but, I think that might be wrong.
You are wrong, but not by much... stock wrx injectors are 450ish, the STi Pink tops are either 655 or 565, I'm dyslexic so i'm not exactly sure what I read. And they are top feeds, which I'm about 95 percent sure is what our ej22's are.
As far as stock ej22, they are in the 240 range, ej22t's are 360
