Loyale 2.7 Turbo Posted September 7, 2012 Author Share Posted September 7, 2012 This is How the Instrument Cluster ended up, after the Deep Cleansing and New LED Bulbs Retrofit, just Before to put it Back in my BumbleBeast: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 7, 2012 Author Share Posted September 7, 2012 (edited) To put Back the Four Vacuum Hoses for the A/C Control Buttons is Easy, because Subaru Marked each one with Numbers... #1, #2 and #4 ...No Number three! ... ... but the last one is unmarked, as the last Vacuum Plug, so No problem at all... ...the Problem is to Keep them in Place, because with Age, those becomes Loose and the Tiny metallic plate that goes in their back, attached to the side's screws, isn't enough to keep 'em Hooked. So, I Used four tiny Zip ties, one for each hose and cutted their excess longitude with a scissors: That shall be More than enough ... ... Edited September 7, 2012 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 7, 2012 Author Share Posted September 7, 2012 Finally, this are the Results: 2 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 7, 2012 Author Share Posted September 7, 2012 (edited) As I wrote: ► You can see that the only part that has Green Tint painted on the instrument Cluster, is the Kilometers per Hour numbers, under the Miles per Hour numbers. ► I managed to Fix the Oil Pressure Gauge, just by sliding it slowly with my Finger, 'till it reached the Real "Top" of the readings, then it sat on the right 0 Mark, not under it as it was. The Dimmer does work Fine with LED Bulbs. Let me Know what do you think about this Mod... Kind Regards. Edited September 7, 2012 by Loyale 2.7 Turbo Misspelled Word... Link to comment Share on other sites More sharing options...
Crazyeights Posted September 7, 2012 Share Posted September 7, 2012 Very nice! Thank you for the write up 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 7, 2012 Author Share Posted September 7, 2012 You're Welcome! ... and you gave me an Idea: I'll post this Ideas on the USRM, because the Threads in the Forums tends to fade away with time, but there this ideas could help more people. Kind Regards. 1 Link to comment Share on other sites More sharing options...
Dee2 Posted September 7, 2012 Share Posted September 7, 2012 Really enjoyed reading this thread. Nicely documented. Thanks for making the extra effort to keep us appraised of the whole job and including the photos. It looks great! I had the same problem with my oil pressure gauge and solved it the same as you did. Unfortunately, I have noticed that with mine, now, the readings always seem to be a bit low. Still, it is better than the negative readings I was getting. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 7, 2012 Author Share Posted September 7, 2012 Really enjoyed reading this thread. Nicely documented. Thanks for making the extra effort to keep us appraised of the whole job and including the photos. It looks great! ... Thank you for your Kind Words. ... I had the same problem with my oil pressure gauge and solved it the same as you did. Unfortunately, I have noticed that with mine, now, the readings always seem to be a bit low... Yes, Same here... I Believe that the Moment the Sender's cable did the Short Circuit that risen the Needle too much, something got stretched within the marker's resistance and then its readings are too low. But I Agree that is Better to see the Gauge Low than to see "Negative" Readings. Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 8, 2012 Author Share Posted September 8, 2012 (edited) Somehow I Believe that the Original Designers of this Instrument Cluster, desired that it looked with Great Contrast, white numbers over black background... but since the incandescent bulbs emit amber Light, they decided to paint the Numbers with a green tint, that the Newer clusters has. The White illumination gives to the car a Much Modern Feeling, and is not Blinding at all, but Camera Lens tend to exagerate the Glow... also I can reduce the Brightness using the Dimmer control. Edited September 8, 2012 by Loyale 2.7 Turbo Misspelled Word, Fixed. Link to comment Share on other sites More sharing options...
nipper Posted September 8, 2012 Share Posted September 8, 2012 This would solve my lighting issue in the Justy. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 8, 2012 Author Share Posted September 8, 2012 I Uploaded a Video and is in HD You can reach it, ~► . Let me Know what do you think about the LED instrument Cluster. Kind Regards. 2 Link to comment Share on other sites More sharing options...
one eye Posted September 8, 2012 Share Posted September 8, 2012 That looks pretty sweet, nice the way you have everything marked and setup in your thread too!!!! I think this would be cool to do on my touring wagon.... Jeff Link to comment Share on other sites More sharing options...
kanurys Posted September 10, 2012 Share Posted September 10, 2012 Looks great. The white light refreshes those old gauges. I saw your oil pressure at 4000 rpm. Classic EA82 engine and gauge reading. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 10, 2012 Author Share Posted September 10, 2012 (edited) Thank you Kanurys and one eye, for you Kind Words. Yes, the White LEDs refreshes those old gauges and also renews the Old interior look -at night times- of these old Subies, now the Dashboard does look "Modern" somehow. Kind Regards. Edited September 10, 2012 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
ontherun987 Posted September 10, 2012 Share Posted September 10, 2012 (edited) Looks great:headbang:, Did you need the replacement sockets? Would these leds work http://www.amazon.com/gp/product/B008IBLJT4/ref=ox_sc_act_title_1?ie=UTF8&smid=A1THAZDOWP300U&tag=ywis-20 http://www.amazon.com/gp/product/B007I7D66S/ref=ox_sc_act_title_2?ie=UTF8&smid=A12J7DMK6HQWCS&tag=ywis-20 Edited September 10, 2012 by ontherun987 Link to comment Share on other sites More sharing options...
tractor pole Posted September 10, 2012 Share Posted September 10, 2012 WOW very nice! I will probably end up doing this while my car is down for an EJ swap:headbang: Ben Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 11, 2012 Author Share Posted September 11, 2012 WOW very nice! ... Thank You! I'm Glad to know that my Ideas will Help other People to Improve their Subies. Looks great , Did you need the replacement sockets? ... No, I used the Original ones, by the way, those are "Toshiba" with their original "Toshiba" Bulbs, also the new ones has the same Brand. About the LED Bulbs I used, let me Share some info and Links: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 11, 2012 Author Share Posted September 11, 2012 - The T-10 ones are These: ~► Here. Those are Perfect fit to the Sockets and the Instrument Cluster. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 11, 2012 Author Share Posted September 11, 2012 - The T-5 ones are These: ~► Here. Those are Perfect fit to the Sockets, the Instrument Cluster and the Upper Left and Right Buttons. Also the Lower Red Stripes with Rectangular Warnings, such as "Oil", "Brake Lamp" , etc... Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 11, 2012 Share Posted September 11, 2012 Thanks! I wonder, I dont see a red or a blue alternative... Would the like stained glass paint work? or do you think itd make the bulbs dim and not be any better than what Ive got now? Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 11, 2012 Author Share Posted September 11, 2012 But there are two T-5 bulbs needed in the Dashboard, one for the "Lights" Button on the Left, and another one for the "Fan Speed" Button on the Right (Early EA82 Models) and that kind of Multiple LEDs T-5 bulb does a Short Circuit with the Surrounding metal ring, somehow... So I Used a couple of Single LED T-5 Bulbs there, with inverted Tip, because those are all Plastic, like the ones pictured Below: 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 11, 2012 Author Share Posted September 11, 2012 Thanks! I wonder, I dont see a red or a blue alternative... Would the like stained glass paint work? or do you think itd make the bulbs dim and not be any better than what Ive got now? I Choosed White, However, there are more Colours to Choose, but Remember that only the Early EA82's clusters doesn't have the Green Tint painted, so in Green Clusters, other Colours than White and Green, should fight that green Tint with unpredictable results, but will Not look Not any Dim like the Standard incandescent Bulbs your Cluster already has. Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 11, 2012 Author Share Posted September 11, 2012 The problem with the Single LED T-5 Bulbs is that their plastic base is So Fat, that the Socket does Expand and don't pass thru the Dashboard's Hole... I had to Press and somehow "Squeeze" those LED's Plastic Base with a Pincers, in order to "Slim" them a Little, 'till I get them in. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 11, 2012 Author Share Posted September 11, 2012 There is a Thread in NASIOC about how to remove the Tint from the Instrument Cluster with Sandpaper, on a Subaru Impreza, Maybe that Ideas could Apply to the Subaru Loyale Green Tint's instrument Cluster. Look Here: ~► http://forums.nasioc.com/forums/showthread.php?t=690378 Kind Regards. Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 11, 2012 Share Posted September 11, 2012 So whats your final bulb tally to replace all the bulbs? I might as well replace all mine... 86 GL so I dont think I have the green tint...? Link to comment Share on other sites More sharing options...
