njdrsubaru Posted March 4, 2007 Share Posted March 4, 2007 Yeah i finally got a way to lift my impreza, not the best way for paying for it (credit card) but i am.. 1. i got forester struts, would i need longer brake lines? 2. will the rear forester strut top fit the impreza wagon? 3. again brake lines all round are they long enough? thanks in advance Neo :-p Link to comment Share on other sites More sharing options...
Andyjo Posted March 4, 2007 Share Posted March 4, 2007 njdrsubaru said: Yeah i finally got a way to lift my impreza, not the best way for paying for it (credit card) but i am.. 1. i got forester struts, would i need longer brake lines? 2. will the rear forester strut top fit the impreza wagon? 3. again brake lines all round are they long enough? thanks in advance Neo :-p I just just forester struts on my OBS... they worked fine, no new caps, not new brake lines, nothing, you should be good to go... you might get a wierd noise from the sway bar/springs but... you'll have that Link to comment Share on other sites More sharing options...
njdrsubaru Posted March 4, 2007 Author Share Posted March 4, 2007 awsome wish me luck i'm going there to do it now Link to comment Share on other sites More sharing options...
Andyjo Posted March 5, 2007 Share Posted March 5, 2007 hope this helps: http://www.ultimatesubaru.org/forum/showthread.php?t=50268 Link to comment Share on other sites More sharing options...
njdrsubaru Posted March 8, 2007 Author Share Posted March 8, 2007 Thanks AndyJo it still hasnt happened due to cold weather but this coming up weekend is a go! i'll keep you all informed with the results Neo Link to comment Share on other sites More sharing options...
theletteri Posted March 8, 2007 Share Posted March 8, 2007 i just swapped my springs for some forester springs. when i need to do struts i will probably use outback of forester struts. that write-up that was posted is perfect. i wish i know about that when i did mine... the springs gave me 2" of lift and the 27" tires gave me 1 more inch for a grand total of 9.1" of ground clearance. that is .3" more than a jeep wrangler X. andyjo: i read your wright-up on the 4wd switch but i cant figure it out on my 06... do you know if it can be done? know of anyone who has done it to an 06? here is a pic of mine! Link to comment Share on other sites More sharing options...
njdrsubaru Posted March 8, 2007 Author Share Posted March 8, 2007 Awsome! it looks like i have to swap the strut tops, the forester is different than mine Link to comment Share on other sites More sharing options...
njdrsubaru Posted March 11, 2007 Author Share Posted March 11, 2007 http://www.ultimatesubaru.org/photos/showgallery.php?cat=975&ppuser=0 :lol: :lol: :banana: :banana: :-p ok ok i'm enjoyng it too much, its awsome, i still have to go back to the rear struts and add some washers to the top so i stops knocking, other than that shes ready for Pine Barrens... thanks guys Link to comment Share on other sites More sharing options...
Andyjo Posted March 12, 2007 Share Posted March 12, 2007 "njdrsubaru has exceeded their stored private messages quota and can not accept further messages until they clear some space." in a reply to your message... I'd suggest loosening it up with the wheel stil on the ground, at least to break it free.. because it's impossible to remove with the whole strut assembly out of the car... it's actully the 1st thing i did. good luck! Link to comment Share on other sites More sharing options...
njdrsubaru Posted March 12, 2007 Author Share Posted March 12, 2007 thanks Andyjo, i got it done and also cleaned up my mailbox lol look at the pics Link to comment Share on other sites More sharing options...
