JSwinbourne Posted March 5, 2007 Share Posted March 5, 2007 Im "restoring" my 78 brat, and for now i'm using the stock motor. It's th single carb 1.6 liter. I'm going to give it a complete overhaul, and was wondering if I could convert it to the dual carb setup. Are there any differences between the two motors, like internally? Whould it be worth the time and effort, or would I be better off sticking to the original set up? Thanks. Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted March 5, 2007 Share Posted March 5, 2007 They did make duallies for the ea71 and ea81.So you could either put on the ea71 duals or change out your engine and go with an ea81 and put duals on that.Nothing needs to be changed internally on the motor as you asked. Link to comment Share on other sites More sharing options...
DR DLEX Posted March 5, 2007 Share Posted March 5, 2007 I've been running the duel carb set-up for a while now on my ea71. The set-up I am using as i was told(sold)is from a 1400cc block.The carbs are the OLD type(DCG-306W-5[ R & L ]).The manifold is a bit taller so I used longer bolts,but it matched up fine.They are manual choke carbs(not enough room between for auto-choke)so routing a cable is a must.I use the same throttle cable,but moved the butt-clamp to the bell housing bolt.I had to simplify vacuum lines as there is not a vacuum modulator.I had to build an air box and route the pcv hoses.As for perfomance....wow what a differance. My one-ton rust bucket accually likes hills,mud,and slush. It has a 3rd gear pull from 15 to 65+(torque through horsepower)floored.I think the points keep the top RPMs down.As for your rebuild,use your existing carb. set-up for enginebreak-in.The duels let alot of air/fuel in quickly,thus stressing every nut holding the heads on.This could make for a long walk with a tight fresh block. Also, ckeck your state smog rules,unless your '78 is age exempt. HAVE FUN Link to comment Share on other sites More sharing options...
kiwi subbie Posted March 6, 2007 Share Posted March 6, 2007 i was thinking of fitting dual carbs to my ea71 engine. i just not sure what would be the way to go... either fit dual carbs or an webber carby to it. whats would be the better 1 to go for? Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 6, 2007 Share Posted March 6, 2007 I Suggest to Go Weber, it´s Simplier and Far Away Better than the Craptachi Carb that came Stock... I was Wonderin´ if a Dual Webers 32/36 Will be a Great idea, or if only with That, the Engine will Become a Huge Gas Eater? Well... I suggest go Weber. Good Luck! Link to comment Share on other sites More sharing options...
