oil pressure on a EJ22?
suberdave
I think that's right....
but you could hook up the oil light from the ECU and see for sure.
The oil pressure light is rated at something ridiculous like 5 psi if I remember correctly. Basically if you have NO oil pressure, it comes on.
yer just a swappin mother ************er aint ya....
anyone know what the oil pressure on a EJ22 should be?
i just finisned my swap on my lifted wagon, and off idle the oil pressure is fine (40-60PSI) but at idle it drops down to like 15PSI. is this to low?
i just went through the engine all new gaskets up to and including head gaskets...
-=Suberdave=-
www.suberdave.com
i have the oil light hooked up also, and it never comes on.
Details on gauge being used, sender, etc...
the gauge is a autogauge manual gauge with the copper tube running out to the pressure sender
im a teacher with some time off. i eather do this or get into trouble...
a few pics... i know it leaks a little. i didnt put any teflon tape on it. that is fixed now...
-=Suberdave=-
http://www.suberdave.com
