carfreak85 Posted March 6, 2007 Share Posted March 6, 2007 I want to put a full time 5 speed tranny in my EA81, and after reading GeneralDisorder's write up on putting EA82 rear DOJs on EA81 rear axles. I got to thinking, "Would it be possible to do this to the front axles as well except using EA82 25 spline cups?" I imagine it would, but just wanted to ask around. What do you think about the reliablility/durability of these hybrid joints? Thanks for all input! Link to comment Share on other sites More sharing options...
86BRATMAN Posted March 6, 2007 Share Posted March 6, 2007 I successfully mated ej22 doj cups to 2wd ea81 alxes for my swap. 4wd's won't work. I was going to try the ea82t doj's but didn't want to pay for the axles Link to comment Share on other sites More sharing options...
carfreak85 Posted March 6, 2007 Author Share Posted March 6, 2007 Bump! Link to comment Share on other sites More sharing options...
SuBrat84 Posted March 7, 2007 Share Posted March 7, 2007 I am putting ea82t inner and outter DOJ's on an ea81 shaft, is that what you mean? Because I put a 5 speed w/ rear lsd and 4 wheel disc brakes in my brat. I have to have them made still but I am told they will work just fine. Link to comment Share on other sites More sharing options...
carfreak85 Posted March 7, 2007 Author Share Posted March 7, 2007 Yeah, that is exactly what I'm asking! Only difference is that I want to do this myself, not pay to have it done. Basically, I want to know if its physically possible to put 25 spline EA82 inner cups on the inboard side of an EA81 axle and if it will last. Is it safe to do this myself, or is it something that should be left to professionals? Link to comment Share on other sites More sharing options...
86BRATMAN Posted March 7, 2007 Share Posted March 7, 2007 I don't see why the wouldn't last. All you are doing is swapping cups, not the whole joint. As long as you get the retaining ring back in place there shouldn't be any problems as long as the axle is in good shape to begin with. Link to comment Share on other sites More sharing options...
Phizinza Posted March 7, 2007 Share Posted March 7, 2007 86BRATMAN said: I successfully mated ej22 doj cups to 2wd ea81 alxes for my swap. 4wd's won't work. Now this is something that has been missing in my knowledge.. Are the 2WD axles the 3 roller bearing style, and the 4WD axles the 6 ballbearings in the race design? Or what? I know my front axles in my 4WD Brumby/Brat have the 6 ballbearing style and the 89 AWD Liberty/Legacy uses the same design only with 25 spline cups like the FT gearboxes. Basicly, what are the differences between FWD and 4WD axles? Sorry for the slight offtopic. Link to comment Share on other sites More sharing options...
86BRATMAN Posted March 7, 2007 Share Posted March 7, 2007 The 2wd's have the same setup IIRC. Just made 2mm smaller around. I put them together about a month ago and didn't really pay to close of attention. I just knew they worked from reading up on here. Also it is about an 95% chance they have to be oem 2wd axles. ALL the parts stores here list the exact same axle for both 2wd and 4wd. On the 2wd hatch I picked up for parts I got really lucky with the one replacement axle that was actually the correct size. The other was rebooted oem. But it fit like a glove. Link to comment Share on other sites More sharing options...
Phizinza Posted March 7, 2007 Share Posted March 7, 2007 86BRATMAN said: The 2wd's have the same setup IIRC. Just made 2mm smaller around. Another stupid thing from the car manufacturing geniuses Link to comment Share on other sites More sharing options...
