beataru Posted March 7, 2007 Share Posted March 7, 2007 This just in... I ordered my exhaust manifold gaskets and they came in a nice little box with a part number on them!!! I dont know how old these are but, I think the part number is still the same, They are Fel-Pro 92996, I hope this helps someone.... Finally I will hit at least stock boost level again, my car will move out of its own way! Link to comment Share on other sites More sharing options...
Phizinza Posted March 7, 2007 Share Posted March 7, 2007 When putting these gaskets on I use aluminium alfoil about 2 layers thick wraped around the gasket. I only get exhaust leaks when I hit something offroad now. Where I used to get exhaust leaks all the freakin time. Link to comment Share on other sites More sharing options...
beataru Posted March 8, 2007 Author Share Posted March 8, 2007 Ok... Ill give that a try, the whole reason this started is because the bolts fell of the header, has this happond to you? I had to go buy new nuts from ace hardware (SS by the way:banana:) and I also put lock washers underneath them, but The stock nuts have little bumps on them to lock them, Does anyone know where to get these nuts? Link to comment Share on other sites More sharing options...
Snowman Posted March 8, 2007 Share Posted March 8, 2007 I haven't looked at the fel-pros myself, but if they don't have the little metal ring around the inside like the OEM gaskets, they will blow out after a while. Link to comment Share on other sites More sharing options...
beataru Posted March 8, 2007 Author Share Posted March 8, 2007 Yeah they have the little ring. Is there a certain way there supposed to fit? Link to comment Share on other sites More sharing options...
mikeshoup Posted March 8, 2007 Share Posted March 8, 2007 Ok... Ill give that a try, the whole reason this started is because the bolts fell of the header, has this happond to you? I had to go buy new nuts from ace hardware (SS by the way:banana:) and I also put lock washers underneath them, but The stock nuts have little bumps on them to lock them, Does anyone know where to get these nuts? I usually don't worry about that. If the nut falls off, I usually put a second one on there and tighten it down on top of the first nut. Keeps 'em from coming off. Link to comment Share on other sites More sharing options...
joostvdw Posted March 9, 2007 Share Posted March 9, 2007 I've had to replace some studs in the turbo and in the heads a while ago and got all the hardware from a toyota dealer, apparently they use the same threads as subaru (M10x1.25) those nuts where of the self-locking type with the little bumps on them, just like the originals. Link to comment Share on other sites More sharing options...
beataru Posted March 9, 2007 Author Share Posted March 9, 2007 Really? is there a specific toyota model that has these studs? Link to comment Share on other sites More sharing options...
mikeshoup Posted March 9, 2007 Share Posted March 9, 2007 The studs and nuts are available from Subaru FYI Link to comment Share on other sites More sharing options...
joostvdw Posted March 9, 2007 Share Posted March 9, 2007 The studs and nuts are available from Subaru FYI yes ofcourse that is your main source, but the subaru dealers here didn't have them in stock and anything older then a legacy sounds like mumbo jumbo to them, so I kinda figured it out on my own. I don't know which model toyota has them, I guess they all do, I just asked for M10x1.25 exhaust studs and they worked like a charm. You might want to bring an old nut with you though, to make sure you have the proper studs. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 9, 2007 Share Posted March 9, 2007 When putting these gaskets on I use aluminium alfoil about 2 layers thick wraped around the gasket. I only get exhaust leaks when I hit something offroad now. Where I used to get exhaust leaks all the freakin time. Aluminium Foil Wrappin´ the Gaskets! Nice Very Good Idea!!! Thanx! Link to comment Share on other sites More sharing options...
beataru Posted March 10, 2007 Author Share Posted March 10, 2007 ok, next time I go to buy my dads parts for his Taco, ill askem how much they are... I dont plan on breaking anything this weekend, but you never know, Leverage is my friend Link to comment Share on other sites More sharing options...
