What should i do while i have my EJ22 out
So I am going to be swapping my EJ22 from my legacy to my impreza and i was wondering what should i do to it while i have it out.
I plan on doing so far:
timing belt
water pump
valve cover gaskets
rear main
front main
clutch/resurface flywheel
any other stuff i should do while i have it out and it's easy to get to.
The motor only has 118k miles on it so i don't think doing head gaskets would be necessary. it's never had any over heating issues or every ran bad.
  86BRATMAN said:
ej22t pistons, crossmember, manifole, uppipe, turbo, downpipe...
Good point, don't want to forget those! Replace at least the geared timing belt idler 13085AA080 near the water pump, and maybe a new tensioner. Replace rear main seal retainer with a metal one if you have plastic. Reseal oil pump (remove, check rear case screws for back out, maybe put a little green loctite on, replace pump to block o-ring, reseal with permatex ultragrey or anaerobic), check whatever those clutch related bearings are such as pilot, throwout, etc., replace thermostat&gasket since water pump will be off anyway.
Cam seals?
I replaced the tensioner and timing belt idler and pulleys at 150K and the engine ran a lot quieter, never realized how much over time that the front of the engine was getting so noisy.
