WJM Posted March 11, 2007 Share Posted March 11, 2007 So....everything was DEAD on my RX last night. Why? Fuseable link. Took me 4 hrs to find that out... why? The FL's were the first thing I checked... 0.0 ohms of resistance....CHECK 12.7 volts on BOTH sides of the FLs....CHECK Felt like new FLs......CHECK Looks like new FLs....CHECK HOWEVER...still nothing. Replace them with NEW FLs....everything works. ARG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I'm going to retrofit some slow blow fuses there instead. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 11, 2007 Share Posted March 11, 2007 That´s Why I Eliminated in 1994 the Fussible Links of my EA82, and Placed Direct Welded Wires... I leave one of the Battery´s Terminals not too Tight, to Remove it in a Emergency case... Never had any Problem. Link to comment Share on other sites More sharing options...
Gravityman Posted March 11, 2007 Share Posted March 11, 2007 Dude NO... Fusable links kick butt!!! They are a dime a dozen in the junkyard. Make the fusable link the first thing you check when you are having any electrical issues and then go from there. My buddy has an old ford that has fusable links that are non-replacable and you cannot check to see if they are blown, so be glad that they are extreamly servicable. The first time I had to deal with them they sucked but once you know to look at them first then they turn out to be your best friend! Link to comment Share on other sites More sharing options...
WJM Posted March 11, 2007 Author Share Posted March 11, 2007 Fuseable links are NOT as cheap as normal fuses...either Fast blow or slow blow. That and you gotta rememeber that me and JWX have like...50% of the old school subies in the south east...the rest...either long gone, owned and running...or missing fuseable links. Link to comment Share on other sites More sharing options...
Cougar Posted March 11, 2007 Share Posted March 11, 2007 If the problem wasn't due to a bad connection on the top side of the fuse holder then the trouble may be on the bottom side. Link to comment Share on other sites More sharing options...
daeron Posted March 11, 2007 Share Posted March 11, 2007 thats right, read MY subject header.. you got it wrong, they don't suck, they BLOW! You can retrofit a MaxiFuse block on instead of the fusible links.. that looks alot cooler, too In your other thread I mentioned my occasional DOA problem.. All i ever do is wiggle the terminal connections on the hindmost fusible link to get it to work. Something tells me you may have been in a similar situation, so it may well come back to haunt you even with your new links. Be glad you don't have the Issue that *I* am stuck with.... My Zcar caught FIRE because i (idiotically) put an oversized link in to replace one that had blown.. the circuit got shorted again, the link heated up, melted the plastic cover i had JUST found in the junkyard and put on there, and set the plastic on fire. The ENTIRE link block, and the wiring going ALL the way down to (but thank goodness, not IN to) the main engine wiring harness, got TOTALLY fried, and thats why Shawn no drivey his Zcar anymore. the silver lining was, thats when I got my Subaru. Well, it WAS silver at one point, now its more like a "rusty lining" Link to comment Share on other sites More sharing options...
4x4_Welder Posted March 11, 2007 Share Posted March 11, 2007 Yes, fusible links were one of many things the Japanese engineered into their cars to punish us for the atomic bomb. The ones on the Hatch are getting replaced with fuses. Link to comment Share on other sites More sharing options...
DaveT Posted March 11, 2007 Share Posted March 11, 2007 Loyale 2.7 Turbo said: I leave one of the Battery´s Terminals not too Tight, to Remove it in a Emergency case... Never had any Problem. This won't save your car. If you get a good short circuit, you can have fire instantly all along the harness from the link box to the point of failure. Been there done that. Even if you don't set the car on fire, the harness will be trashed before you can get to the battery cable. Link to comment Share on other sites More sharing options...
Indrid cold Posted March 11, 2007 Share Posted March 11, 2007 DaveT said: This won't save your car. Even if you don't set the car on fire, the harness will be trashed before you can get to the battery cable. ....... 2nd that, "ARC" then SMOKE, about that quick, work in fuse's of some kind... $1. to protect hundreds... cheap insurance. Link to comment Share on other sites More sharing options...
psylosyfer Posted March 26, 2007 Share Posted March 26, 2007 The fusible links showing 0 ohms are not blown (open), and they do perform better than a fuse in a hi current(amp) short. In my experience with EA82's, It's the spade lug connectors that comes up through the bottom of the plastic case, They corrode, Sometime the corrosion causes a resistance which creates heat, softening the plastic so the little spurs on the male connector shoves down out of the hole making it hard to push the female half (the part on the fus.link) on the male without pushing the male down and out, failing to connect (plug in).That is what sucks! As you found out they work fine until they fail 100% and the car don't go! It is a hassle to reach from under the plastic case feel for the one your plugging in and pushing it up while pushing the top connector down, Of course its even harder to connect because the corroded lugs don't want to fit as well as intended. All you can do is remove as much corrosion as possible. Then make sure they are plugged in good then a shot of WD or something to help slow the corrosion. Or replace the spade connectors. The bright side is it will never take long to figure out the problem. If it happens again after your hip to it, It should take all of a minute to get out and push the top and bottom together while wiggling a little to make a connection through the corroded plugs. When you replaced them you mananged to scrape through the corrosion enough to make connections, Could have done same thing with the old ones. A note for the fella from Honduras, Pulling the battery cable won't help unless you can get out and do it in under about five thousandths of a second! And you'll need to know ahead of time that your about to have a short! An awesome skill if you can!! fusible links are designed to blow around 5 to 9 millionths(microseconds) of a second, a fast acting fuse only has to work under 250 thousandths(milliseconds) of a second. Dealing with the speed of light, After the fact is always too late to save any parts from damage. Link to comment Share on other sites More sharing options...
subaruguru Posted August 16, 2007 Share Posted August 16, 2007 i hate them as well i am getting a newer fuse box and getting glow blows when the fuse blows a filiment inside lights up so if i have a problem i just have to see what one is lit up. :cool: Link to comment Share on other sites More sharing options...
psylosyfer Posted August 16, 2007 Share Posted August 16, 2007 glow blows? where do you get them? Link to comment Share on other sites More sharing options...
r_kirky Posted August 17, 2007 Share Posted August 17, 2007 The one for my 96 legacy was around 20$ through subaru:confused: Link to comment Share on other sites More sharing options...
subaruguru Posted August 17, 2007 Share Posted August 17, 2007 i have seen them at schucks i the fuse section they are really neat Link to comment Share on other sites More sharing options...
84gl Posted August 22, 2007 Share Posted August 22, 2007 WJM said: Fuseable links are NOT as cheap as normal fuses...either Fast blow or slow blow. That and you gotta rememeber that me and JWX have like...50% of the old school subies in the south east...the rest...either long gone, owned and running...or missing fuseable links. If have 50% will I have the other half 2 rx 3doors 1 rx 4door 8 wagons 2 hatches one ejed and brat with a nuff parts laying around to build 10 more Link to comment Share on other sites More sharing options...
WJM Posted August 22, 2007 Author Share Posted August 22, 2007 Ok, you've got the other 50%. Link to comment Share on other sites More sharing options...
