howlemup Posted March 11, 2007 Share Posted March 11, 2007 Anybody have any experience with this lift for an EA82 wagon, how hard is it to install? Quality? What size tires can you run with fender trimming, just basicly any thing good or bad about this lift. Thanks Link to comment Share on other sites More sharing options...
Uberoo Posted March 11, 2007 Share Posted March 11, 2007 SJR stuff is pretty good.However you will need to buy bolts and extend your steering shaft in the engine bay.Also you will most likely need to extend your brake lines.From what I had heard of the installs it could take about a day or so if you install it in your driveway. Link to comment Share on other sites More sharing options...
howlemup Posted March 11, 2007 Author Share Posted March 11, 2007 Uberoo said: SJR stuff is pretty good.However you will need to buy bolts and extend your steering shaft in the engine bay.Also you will most likely need to extend your brake lines.From what I had heard of the installs it could take about a day or so if you install it in your driveway. Thanks Link to comment Share on other sites More sharing options...
Uberoo Posted March 11, 2007 Share Posted March 11, 2007 I know that you can fit 30's with a 4" lift problem is that anything above 27" and your offroad hill climbing ability goes down,unless you do something to the motor.Myself I am gonna run 31X10.50 with 4.5" lift and I have an ej22 to provide movement. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted March 16, 2007 Share Posted March 16, 2007 Uberoo said: SJR stuff is pretty good.However you will need to buy bolts and extend your steering shaft in the engine bay.Also you will most likely need to extend your brake lines.From what I had heard of the installs it could take about a day or so if you install it in your driveway. bolts are provided , unless you chose not to get them, all kits can be customized to your specs, Scott Link to comment Share on other sites More sharing options...
Phizinza Posted March 16, 2007 Share Posted March 16, 2007 Not to do with the llift here, but.. Personally I wouldn't go above 28" tires on a any subaru without gearing modifications.. So, my advise is, start with 27's or 28's and see how you like it, if it's ok in your mind, then you may try bigger. Just don't get stuck with huge tires you don't like. I like crawling over things, so that might explain something. Yes, I know subarus can't crawl, but I try! Link to comment Share on other sites More sharing options...
