um
I wired in my EJ harness to various connectors on the EA dash-tach,charge light,CEL,,ignition positive off ignition switch.
my question is I have no indicator lights at startup no CEL,no charge,no oil,no nothing in the instrument brezel.When I tried to see if the motor would crank when the battery was just hooked to the charger.Anyway when I tried to see if it would crank I heard this clicking from behind the dash.Also when I tried it I didn't have the ECU memory wire hooked up or the wires from the alternator to the battery.Could that be a cause of the problem?I'll try connecting the memory wire to something tommarow.that and my open fuel line pumped some fuel on the engine(carbie pump still attached:dead: ) need to wire in FI fuel pump and FI lines.
