3Pin Posted March 17, 2007 Share Posted March 17, 2007 I just bought a 98 Forester 2.5 DOHC automatic with what I thought was Timing belt failure with bent valves, but it turns out the knuckelhead actually drove it in an overheated state for about 25 miles until it just burned up. My trusted mechanic who has done about 3 other subaru's like this took it out of the car and took a look at it and said--- time for new motor. I have looked for another 2.5, but they are quite pricey. I found a local 95 2.2 from an automatic and have researched the threads and it appears that it is a pretty clean swap once the flywheel is swapped. Any red flags from any of you on this plan? I can get the 2.2 with about 90k on it for $400.00 with a 30 day warranty. I need to decide Monday if you all can chime in, I would appreciate it. Link to comment Share on other sites More sharing options...
porcupine73 Posted March 17, 2007 Share Posted March 17, 2007 Might want to check with ccrengines.com for prices. AFIAK the 2.2L should work but it isn't going to have the power of the 2.5 dohc that was in there (if that matters to you). Link to comment Share on other sites More sharing options...
schlit Posted March 17, 2007 Share Posted March 17, 2007 I just bought a 98 Forester 2.5 DOHC automatic with what I thought was Timing belt failure with bent valves, but it turns out the knuckelhead actually drove it in an overheated state for about 25 miles until it just burned up. My trusted mechanic who has done about 3 other subaru's like this took it out of the car and took a look at it and said--- time for new motor. I have looked for another 2.5, but they are quite pricey. I found a local 95 2.2 from an automatic and have researched the threads and it appears that it is a pretty clean swap once the flywheel is swapped. Any red flags from any of you on this plan? I can get the 2.2 with about 90k on it for $400.00 with a 30 day warranty. I need to decide Monday if you all can chime in, I would appreciate it. Might want to look into this, but I thought it was illegal to put an older engine into a newer car. Link to comment Share on other sites More sharing options...
3Pin Posted March 17, 2007 Author Share Posted March 17, 2007 I have never heard of this. As long as the pollution stuff all works, it should be fine. Where did you hear this? Link to comment Share on other sites More sharing options...
cricket Posted March 17, 2007 Share Posted March 17, 2007 Buy another 98 Forester and keep this one for parts. Link to comment Share on other sites More sharing options...
86BRATMAN Posted March 17, 2007 Share Posted March 17, 2007 I have never heard of this. As long as the pollution stuff all works, it should be fine. Where did you hear this? Its a commonalitly for motor swappers. But you could always claim ignorance. Link to comment Share on other sites More sharing options...
cookie Posted March 18, 2007 Share Posted March 18, 2007 With a 2,2 that would be a nice car. They came with 2.2s in other parts of the world. If everthing worked it would be rare for someone to notice the swap and several folks have done it. Check to see if they look at engine numbers where you live in an inspection. Ask your mechanic friend as it could be a pain if they do. Link to comment Share on other sites More sharing options...
3Pin Posted March 18, 2007 Author Share Posted March 18, 2007 This is what I found on the legality of the whole thing. I was more interested in hearing if anyone had done one. Rules regulating engine swapping are not make/model specific. The simple rule is that a vehicle must have all emissions components that were present when it was manufactured, which may include: PCV - positive crankcase ventilation ACL - air cleaner (thermostatic air cleaner) AIS - secondary air injection EGR - exhaust gas recirculation EVAP - evaporative emission CAT - catalytic convertor SPK - spark control FR - fillpipe restrictor O2S - oxygen sensor Link to comment Share on other sites More sharing options...
3Pin Posted March 18, 2007 Author Share Posted March 18, 2007 Thanks Cookie. They don't look at engines here and as long as the CEL light is off, you pass. Link to comment Share on other sites More sharing options...
cookie Posted March 18, 2007 Share Posted March 18, 2007 then that would be the way to go. I needed the interior height of a Forester but I hated to get a 2.5. I reckon if it ever dies it gets a good old 2.2. Link to comment Share on other sites More sharing options...
lmdew Posted March 18, 2007 Share Posted March 18, 2007 Easy sway and the price on the 2.2 is good. Just a little less power, but it will run for ever. Link to comment Share on other sites More sharing options...
msmithmmx Posted March 18, 2007 Share Posted March 18, 2007 A 2.2 for 400.00 is to much, I would offer 200.00. Given no facts. you may have to reseal the engine. The 2.2 swap needs a few things other then the motor. Make sure the 2.2 includes the exhaust manifold. 1) Engine / use the exhaust manifold from the 2.2 donor 2) AC Compressor you must keep and hoses from your 2.5 mount onto the 2.2 3) Metal Power steering lines from the 2.5 move them over 4) The fly-wheel from the 2.5 will have to be moved over to the 2.2. Link to comment Share on other sites More sharing options...
3Pin Posted March 18, 2007 Author Share Posted March 18, 2007 Thanks for the comments all. msmithmmx, quick clarification, do I need to make sure the 2.2 AC compressor comes with the donor engine or retain my AC compressor from the 2.5? Link to comment Share on other sites More sharing options...
msmithmmx Posted March 18, 2007 Share Posted March 18, 2007 Thanks for the comments all. msmithmmx, quick clarification, do I need to make sure the 2.2 AC compressor comes with the donor engine or retain my AC compressor from the 2.5? To Clarify 1) You will need the AC Compressor and hoses from the 2.5. 2) You will need the metal power steering lines from the 2.2 donor car. They discoonect right above the front cross member. 3) If you go with the 2.2, I suggest you reseal what you can during the swap Link to comment Share on other sites More sharing options...
