EA82 1/4mile Times
'mattyg41383' did a 14.586 @ 92.72 and a 14.868 @ 91.53
Specs:
*Weight Reduction -- Stripped interior, AC, all the random stuff to strip.
*Tranny Cooler
*Gauges -- big tach, boost, oil press, water temp
*Swapped on V-belt pulleys instead of the serpentine setup.
*Stock internals
*Saab 900 intercooler -- rigged with homedepot pipe (smoother pipe is in its near future.
*2.5" downpipe to Dynomax Race Bullet muffler
*Boost @ 15psi -- just put a plastic tee in the wastegate line so it bleeds off. (I also have a better MBC in the works, but its not consistent enough to run yet)
*5th injector. {Saab cold start injector, run off a pressure switch and a relay... much discussion about this on the board}
*Gutted right headlight = Ram Air
*K&N filter in the stock airbox.
I estimated mine @ about 16 or so, but that was at 7200' and timed with my CD player :-P It was bone stock except no muffler and I hollowed out the airbox. (and 15 psi due something bein f'ed up.. Not sure what, but my 88 XT engine runs 8psi lol..)
