XSNRG Posted November 24, 2003 Share Posted November 24, 2003 I hoping somebody can supply me with the folowing info: Section 4-1, suspension specs, GL-10 Turbo Sedan, Coefficient of springs, Front? Rear? Damping Force Front? Rear? Thanks! Quote Link to comment Share on other sites More sharing options...
baccaruda Posted November 24, 2003 Share Posted November 24, 2003 you have mail Quote Link to comment Share on other sites More sharing options...
XSNRG Posted November 24, 2003 Author Share Posted November 24, 2003 Did you mail me again? I got the one about the TB. Do you have a '86 manual? Thanks Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 24, 2003 Share Posted November 24, 2003 Front - GL-10 Sedan 2wd is 134lb per in. 4wd is 157lb per in. Rear - GL-10 Sedan 2wd is 159.6lb per in. 4wd is 159.6lb per in. Rob Quote Link to comment Share on other sites More sharing options...
XSNRG Posted November 24, 2003 Author Share Posted November 24, 2003 Thanks Rob, Could I get the damping force too? Is that from the '86 manual? Thanks! Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 24, 2003 Share Posted November 24, 2003 All info is from the 86 FSM. The 4wd stats are for the RX Turbo. Front 2wd - Expansion,176lb/Comp,110lb 4wd - Expansion,309lb/Comp,265lb Rear 2wd - Expansion,176/Comp,110lb 4wd - Expansion,309lb/Comp,221lb Rob Quote Link to comment Share on other sites More sharing options...
Warp3 Posted November 24, 2003 Share Posted November 24, 2003 Hey, while you are looking up 1986 FSM specs, do you mind looking up the curb weight of a 1986 Subaru RX Turbo Sedan? All the results I can find are for overseas models or different model years (and I think the later RX models may actually weigh more). Thanks! Quote Link to comment Share on other sites More sharing options...
XSNRG Posted November 25, 2003 Author Share Posted November 25, 2003 Awesome Rob, thanks. Are the GL-10 turbo 4WD and RX listed in the same column? That's how it's listed in the '87 manual. Thanks again, Mark. Quote Link to comment Share on other sites More sharing options...
Warp3 Posted November 28, 2003 Share Posted November 28, 2003 Originally posted by Warp3 Hey, while you are looking up 1986 FSM specs, do you mind looking up the curb weight of a 1986 Subaru RX Turbo Sedan? All the results I can find are for overseas models or different model years (and I think the later RX models may actually weigh more). Thanks! Does anyone know the answer to this question? I can't seem to find an accurate answer no matter how hard I search!? :-\ Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 28, 2003 Share Posted November 28, 2003 Sorry bout that, missed this post. Theres alot of differences in weight between the models and options. This is for the 5spd D/R - 1,143lbs. Rob Quote Link to comment Share on other sites More sharing options...
Warp3 Posted November 28, 2003 Share Posted November 28, 2003 Originally posted by Turbone Sorry bout that, missed this post. Theres alot of differences in weight between the models and options. This is for the 5spd D/R - 1,143lbs. Rob Umm...that sounds a little light. Are you sure that isn't just the weight for one half of the car!? LOL (I know the '89 FSM lists 3 curb weights per model: front, rear, and total.) And yes, I am requesting the info for the 5spd D/R model. Thanks for the help, Quote Link to comment Share on other sites More sharing options...
Ben L Posted November 28, 2003 Share Posted November 28, 2003 it said on my title 2600 lbs. my car is an 86 rx turbo sedan as well. Quote Link to comment Share on other sites More sharing options...
