Durable wheel paint
I usually use Rust-o-leom applicance epoxt paint.
This perfect for our wagon wheels b/c it comes glossy white. The other colors are glossy black and almond. (gee go figure. The three most popular applicance colors) Anywho, it's designed to be durable and fairly scratch resistant.
  4x4_Welder said:
...and use the 500º ceramic high temp paint. ...
I Think that Ceramic Paint won´t Bear Off Roadin´ Conditions... You Know, Rocks, Hits, etc...
I Suggest Epoxy Paint, the one used on "Safe Bank Boxes" (I´m Lost in Translation) that will Last more to the Impacts.
Good Luck! :burnout:
Epoxy paint is the way to go. Once that stuff is on there, it's NEVER coming off. We use it on all kinds of stuff at work, mostly trailer decks that see tons of abuse. Usually the plywood comes apart before the paint comes off.
  Zebisko said:
Would I be able to get a white epoxy? Would it look good? What is a good brand, and where to buy?
Yeah, I've seen it in white or grey. I don't know the brand, but we get it from the local hardware store. It's commonly used to paint concrete floors.
If you have access to a air compressor and paint gun, you can get epoxy paint at sherwin williams. Thats what I spray on the trailers and truck beds at work. Like said before the wood goes bad before the paint.
With the white though, be warned, any rust will bleed through if you don't prime and seal it correctly.
