michael appel Posted March 29, 2007 Share Posted March 29, 2007 What do I have to do to get atv rims to fit?? Link to comment Share on other sites More sharing options...
Jibs Posted March 29, 2007 Share Posted March 29, 2007 A lot of people are gonna tell you not to do it because of the weight issue, but Sweet82's done it. I know there's a couple of atv rims that are close to our bolt pattern. (I heard like 4 x 139.7mm or something close.) Check around, some of the atv tires nowadays are getting to handle more and more loads. Link to comment Share on other sites More sharing options...
michael appel Posted March 30, 2007 Author Share Posted March 30, 2007 thanks Link to comment Share on other sites More sharing options...
crazy D Posted March 30, 2007 Share Posted March 30, 2007 hey mike, kawasaki rims are the subaru bolt pattern, you just have to drill the holes bigger so they will fit around the lug. Link to comment Share on other sites More sharing options...
michael appel Posted March 30, 2007 Author Share Posted March 30, 2007 do you remember the size and bolt pattern? Link to comment Share on other sites More sharing options...
Uberoo Posted March 30, 2007 Share Posted March 30, 2007 some ATV tires mount to 14" rims FYI Link to comment Share on other sites More sharing options...
Numbchux Posted March 30, 2007 Share Posted March 30, 2007 A lot of people are gonna tell you not to do it because of the weight issue, but Sweet82's done it. I know there's a couple of atv rims that are close to our bolt pattern. (I heard like 4 x 139.7mm or something close.) Check around, some of the atv tires nowadays are getting to handle more and more loads. Sweet82 has custom rims and ATV tires. and no body.....it's substantially lighter than a real soob. this has been discussed a number of times, bottom line being that you're putting something like 5 times more weight on them then most of them were designed for. whether that's a risk you're willing to take is up to you.... Link to comment Share on other sites More sharing options...
Phizinza Posted March 30, 2007 Share Posted March 30, 2007 Theres no way they are going to be used on-road, so the risk of anything but damaging the tire or brake lines and stuff is pretty small.. There was some atv tires talked about which had a much higher load rating, I think it was posted my flyb0y. Check the similar threads below, may get some good info in those. Link to comment Share on other sites More sharing options...
michael appel Posted March 30, 2007 Author Share Posted March 30, 2007 They new polaris and grizzlies all out weight my brat Link to comment Share on other sites More sharing options...
Sweet82 Posted March 30, 2007 Share Posted March 30, 2007 There are issues with any tires. The tires are not my complaint, gearing is! The biggest issue I have is developing the horsepower. With a 22 to 1 crawl ratio, over sized tires take their toll on power. I'd choose your tire size carefully. Steep Climbs are out of the question with way big tires. --Before you say it, if I was going to put in a second transfer case, I'd start with a different platform-- Having said all that, I think your Brat would rock with ATV tires. Link to comment Share on other sites More sharing options...
Numbchux Posted March 30, 2007 Share Posted March 30, 2007 They new polaris and grizzlies all out weight my brat did you forget to put in the motor? seriously though, yes, some of the bigger ATVs are pigs by comparison to other ATVs. but you are going to be hard-pressed to find an ATV that weighs more than 1500. heck, in MN, anything over 900 is no longer considered an Class-1 ATV. (class 2 was just created, is only up to 1500, and so far, there are zero class 2 designated trails) and I have no concept how you might have gotten your brat down to those kinds of numbers I'm not saying it can't be or hasn't been done. I just want to make sure you know that even if you get the highest load rated tire, you'll be pushing it right to the limit. Link to comment Share on other sites More sharing options...
michael appel Posted March 30, 2007 Author Share Posted March 30, 2007 Weight is a big factor and I have been cutting here and there with my stock brat I am around 1500 right now but they make 26 9.50 x 14 tires for atvs so I was pressed on try them out because I thought they might be a little stronger then a 12 inch tire All in all I probably will go 30 with regeared sammi axles and transfer case but I have done that already now im trying something different like staying stock welding the diff in the rear and a 26 inch tire so little involved cutting I only do mud and moderate trails so not to worried about doing crazy jumps and wild stuff just going on trails and leaving behind a bite mark Link to comment Share on other sites More sharing options...
crazy D Posted April 1, 2007 Share Posted April 1, 2007 a stock subaru justy has a curb weight of over 1600Lbs. mike. i dont know how your brat is that light but cheers on however the hell you got it that way. Link to comment Share on other sites More sharing options...
michael appel Posted April 1, 2007 Author Share Posted April 1, 2007 cutting a lot of cutting Link to comment Share on other sites More sharing options...
michael appel Posted April 1, 2007 Author Share Posted April 1, 2007 my next venture is making fiberglass frontend Link to comment Share on other sites More sharing options...
michael appel Posted April 1, 2007 Author Share Posted April 1, 2007 also add the extra equipment as of winch,toolbox and bumpers and some other accessories.... Link to comment Share on other sites More sharing options...
chasrace Posted April 2, 2007 Share Posted April 2, 2007 you need a motor like mine . just a little ea81 i threw together. itdynoed 150 ft lbs of torque at the wheels. im running 30'' tires. http://www.amishoutlawracing.com/VideoHarrisburg2SemiFinals06.htm http://www.amishoutlawracing.com/VideoSubaruShartlesvilleJuly29.html Link to comment Share on other sites More sharing options...
michael appel Posted April 4, 2007 Author Share Posted April 4, 2007 That thing is sweet.... Link to comment Share on other sites More sharing options...
carfreak85 Posted April 4, 2007 Share Posted April 4, 2007 Michael, would you please reply to my PM? Link to comment Share on other sites More sharing options...
