caliplates Posted April 1, 2007 Share Posted April 1, 2007 Does anybody know how to equip an ea81 vehicle with A/C? I have some parts cars with working air conditioning and woul like to switch the A/C over to one or two of my nicer ones. I know the cars are set up for dealer installed A/C, but is it a simple bolt in? the compressor and condenser look like no problem, but is there a different style heater core? What, if anything, needs to be changed under the dash? Has anybody done this before? What I'd really like to get my hands on is the dealer instructions, but those can't exist anymore, can they? Any advice on this would be very helpful! Link to comment Share on other sites More sharing options...
dfoyl Posted April 2, 2007 Share Posted April 2, 2007 I went through the same process a few months back, but on a RHD vehicle instead of LHD and there are "some" differences. You'll need the A/C pulley off the crank from your donor, the wiring loom and relays (if fitted) on the left side shock tower (early EA81s don't have the relays), extra thermo-fan (mounts to the right of the standard unit), and I believe half the heater core changes (it does for RHD for sure). Pulling the heater core is a PITA without removing the dash. There will be an extra cable to run into the blower fan circuit (hidden right in the middle of the dash). I'm sure a few US members will be able to correct any LHD-specific differences... Dean. caliplates said: Does anybody know how to equip an ea81 vehicle with A/C? I have some parts cars with working air conditioning and woul like to switch the A/C over to one or two of my nicer ones. I know the cars are set up for dealer installed A/C, but is it a simple bolt in? the compressor and condenser look like no problem, but is there a different style heater core? What, if anything, needs to be changed under the dash? Has anybody done this before? What I'd really like to get my hands on is the dealer instructions, but those can't exist anymore, can they? Any advice on this would be very helpful! Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 2, 2007 Share Posted April 2, 2007 It's definately going to be easiest to pull the dash. Although it's probably *possible* without doing it, the added effort is worth the end result as you can inspect and clean all the whole vent system and use new foam on all the flapper doors and stuff. GD Link to comment Share on other sites More sharing options...
the sucker king Posted April 2, 2007 Share Posted April 2, 2007 hey i've got all the factory paperwork for ea81 ac including installation. i could scan it later this week and maybe this should be up in the repair manual. Link to comment Share on other sites More sharing options...
caliplates Posted April 2, 2007 Author Share Posted April 2, 2007 Wow all you guys are so helpful! That would be great if you could post that paperwork. Please let me know if you do! the sucker king said: hey i've got all the factory paperwork for ea81 ac including installation. i could scan it later this week and maybe this should be up in the repair manual. Link to comment Share on other sites More sharing options...
