stinky Posted April 6, 2007 Share Posted April 6, 2007 A few weeks back I acquired 2 gearboxes from ebay. 1 was a single range ea82 Fulltime box. The other was an empty shell with two sets of internals, 1 part-time, 1 full-time. This is the second gearbox with some gears in it. What have I made ? I'm hoping to end up with a dual range fulltime box, but in reality have no idea what I'm doing. Gearbox photos Link to comment Share on other sites More sharing options...
Phizinza Posted April 6, 2007 Share Posted April 6, 2007 So you have two sets of center diff's with lockers? Nice score. What is the diff ratios of both the center locker boxes and pinion shafts. See, some of the XT6's came with 3.9 S/R FT4WD boxes I believe.. Now I have a 3.7 FT with the 1.59 low gears, but a 3.9 is about the best setup I can think of.. Sorry if I'm just mubbling non-understandable stuff.. I've just finished for the day on fixing my ute. The pictures you have there.. First one is a D/R FT4WD box with the 1.2 to 1 low. I know this because the pinion shaft is long and holds the center diff. And the gears on the low range aren't different enough in size to get the 1.59to 1.. The picture of the gears just sitting there look like a single range PT box, because the pinion shaft is part if the output gear set and it also has the gear for the selectible 4WD gear.. You want standard L series low gear, D/R FT4WD gear sets, and any casing with the FT4WD rear casing. So I gather you have a FT4WD D/R box that you just pulled apart with the standard 1.2 low gears. A Standard L series box with a S/R FT4WD internals and a Standard S/R L series internals? Is that right? Link to comment Share on other sites More sharing options...
stinky Posted April 6, 2007 Author Share Posted April 6, 2007 What I have there is an abandoned project that I bought from ebay. It consisted of a fully intact single range fulltime box. an empty gearbox ( with a fulltime rear attached to it ) and the internals from two gearboxes, one fulltime ( assume single range ) and one part time ( assume dual range ). I found a 3.7 sticker on the empty gearbox. I'm trying to make a fulltime dual range box out of it. At this stage I'm not too concerned over the low gear as it's for my road car. I don't even need the dual range, but figure I might as well if I can. btw, I don't suppose you could photoshop one of the images and put arrows to which bit is what? Link to comment Share on other sites More sharing options...
Phizinza Posted April 7, 2007 Share Posted April 7, 2007 stinky said: btw, I don't suppose you could photoshop one of the images and put arrows to which bit is what? Like this? Link to comment Share on other sites More sharing options...
idosubaru Posted April 7, 2007 Share Posted April 7, 2007 wow, that's some stellar information right there. Link to comment Share on other sites More sharing options...
daeron Posted April 7, 2007 Share Posted April 7, 2007 grossgary said: wow, that's some stellar information right there. its enough to give me nightmares... one of these days I really have to disassemble and re assemble a complete spare tranny so I can see how all that ************ works together and it doesn't scare me so much anymore. Link to comment Share on other sites More sharing options...
Skip Posted April 7, 2007 Share Posted April 7, 2007 Phiz, you are by far the tranny master !! Thank you for taking the time to explain this. I have a question - on the bottom box shot you say the D/R is a 1.2 set up. Is it true that beside the gears I see sycros? Could this be another way to tell the 1.2 setup? As the RX setup (1.2) is shift on the fly whereas the 1.5 is not? Link to comment Share on other sites More sharing options...
WoodsWagon Posted April 7, 2007 Share Posted April 7, 2007 1.5:1 low is shift on the fly as far as my experience tells me. Link to comment Share on other sites More sharing options...
Caboobaroo Posted April 8, 2007 Share Posted April 8, 2007 I've driven an EA82 d/r where I could shift the 4wd from 2-4 wheel on the fly. Link to comment Share on other sites More sharing options...
Skip Posted April 8, 2007 Share Posted April 8, 2007 Sorry for the confusion, the "shift on the fly" I mention is concerning the hi to low range as that is the gear set I speak of and Phizinza is describing All my D/R trannied Subes except for my RX should not be shifted at any speed above a crawl from hi range into low range. It no doubt can be done but not as easiliy as the RX. Thus my mention of sycros between the gear sets. The RX is made to do this in order to keep the engine in the fat of the torque band in situations not requiring a full gear up/down shift. Yielding essentially a ten speed gear box. Link to comment Share on other sites More sharing options...
WoodsWagon Posted April 8, 2007 Share Posted April 8, 2007 Skip said: Sorry for the confusion,the "shift on the fly" I mention is concerning the hi to low range as that is the gear set I speak of and Phizinza is describing All my D/R trannied Subes except for my RX should not be shifted at any speed above a crawl from hi range into low range. It no doubt can be done but not as easiliy as the RX. Thus my mention of sycros between the gear sets. The RX is made to do this in order to keep the engine in the fat of the torque band in situations not requiring a full gear up/down shift. Yielding essentially a ten speed gear box. This is what i'm talking about too. I shift in and out of low range without any bad noises or resistance at anywhere up to 50mph, in any gear. It's way harder to shift in and out of 4wd than it is to shift from lo to hi. Link to comment Share on other sites More sharing options...
stinky Posted April 8, 2007 Author Share Posted April 8, 2007 Brilliant info! thanks phiz! a quick question : can I remove the low range from the front of shaft or does the whole lot need to come apart ? Also the tab that bolts to the front of the box on it has a snapped section so only has 2 bolt holes. Can it be pulled off the front to be swapped out with a good one. OOOh, also can I swap the dual range gear for a dual range from 4spd gearbox? I assume the dual range gear is the bigger of the two. Link to comment Share on other sites More sharing options...
Phizinza Posted April 8, 2007 Share Posted April 8, 2007 Skip said: I have a question - on the bottom box shot yousay the D/R is a 1.2 set up. Is it true that beside the gears I see sycros? Could this be another way to tell the 1.2 setup? As the RX setup (1.2) is shift on the fly whereas the 1.5 is not? Yes, they are syncros. All the Low range gears, and 4WD selector gears in all the subaru gearboxes (well, atleast EA81 and up) use syncros. I use a 1.59 to 1 low ratio in my FT4WD box and I can easily shift from low to high at anytime (even 100kmph.) And in low, my 5th is about the same as high 3rd. But my low 1st is just too low for street use, even with my 27" tyres. I have found it harder to shift the 5sp PT boxes into 4WD then it is the 4sp PT boxes. I have no idea why. Although I do know the selection shift shafts and forks are a lot more complecated in the 4sp then the 5sp (but remember, I'm talking about PT boxes here, so thats a little off topic.) Link to comment Share on other sites More sharing options...
Phizinza Posted April 8, 2007 Share Posted April 8, 2007 stinky said: can I remove the low range from the front of shaft or does the whole lot need to come apart ? Also the tab that bolts to the front of the box on it has a snapped section so only has 2 bolt holes. Can it be pulled off the front to be swapped out with a good one. Yes, you can remove the front bearing and clutch spline. But... You might need to take a real good hard look at the syncros on the low range because they do fall apart very easily. And it is a bit hard to put them together.. I tell ya what, when my brothers here I will video me putting the low range syncros together for everyone on here. The 1.2 low range uses different size syncros then the 1.5 (well, at least my Liberty EJ D/R gearbox did on it's 1.2 to 1.) This means you will need the 1.5 gears shift fork and you will also need to removed the gears from both the clutch input shaft and the input gearset shaft. You will also need to take out the low range gears (they sit right behind the ones I pointed to in the picture.) All this stuff is held in with split pins and the like. I might see if I can get some better pictures to describe this. stinky said: OOOh, also can I swap the dual range gear for a dual range from 4spd gearbox? I assume the dual range gear is the bigger of the two.I have not yet ripped open the main casing to my 4sp. So I'm not sure, the problem I see is if the syncros are different, and you need the 4sp shift fork, then it's coming out the wrong side of the box. I have heard on AUSubaru that it cannot be done, but no one could explain why not. They just said it couldn't be done. Link to comment Share on other sites More sharing options...
Phizinza Posted April 9, 2007 Share Posted April 9, 2007 Oh and.. For putting the gearbox back together... Professionals will probably cringe at this, but. I done all the diff and pinion torquing myself. I used the pinion shims that came with the casing I used (I wasassuming the casing is going more out from factory then the gear sets.) Then when the two halves were back together I set the side diff plates up so the box had as much back lash as another good box I had. Basicly you want the smallest amount of slop, only you still have to be able to feel the slop. And remember, oil in a box will make the slop feel like less, but in reality it wont have less, it will have more. And BTW, the center diff doesn't need tensioning. Its very much a guess work thing when you don't have the tools. My gearbox is fine, except for a small bearing noise which I think is because the Liberty box I used had the noise and I used the Liberty input gear set. So it must have a bad bearing.. Maybe if I pull it apart to fit a LSD one day I'll fix that. Link to comment Share on other sites More sharing options...
torxxx Posted April 9, 2007 Share Posted April 9, 2007 91Loyale said: This is what i'm talking about too. I shift in and out of low range without any bad noises or resistance at anywhere up to 50mph, in any gear. It's way harder to shift in and out of 4wd than it is to shift from lo to hi. My D/R N/A tranny shifts fine from low to hi or hi to low. I use it like a 10 speed in the winter time. Never makes any bad noises Thats interesting to see that you "arent" supposed to shift them like that. Link to comment Share on other sites More sharing options...
