Blew it up
Well I dont know if anyone was following my serious LEAN/Hesitation Issue latly but after a high speed run to the beach I noticed a loss in power and boost wasnt holding. Also noticed Blue smoke out the back.
Got it back and did a compression test :
150-146-142-65psi
#4 65psi
Tore the block out and inspected it to find this :
bf64698c77ce.jpg?_rh=cahh6apr6xn9jwwl02hiyx5kt
Seems as #4 was running extremly LEAN and Detonating!!!!! chunk of piston missing :(
I had the injectors flowed and it turns out #4 was screwed up so that was the problem the whole time but I didnt catch it in time.
Well I just finished installing another new SOA shortblock around 7pm hopfing to get it running for Subiefest but I just couldnt make it. Sorry to everyone who wanted to see it.
Anyways
Just had to vent a llittle.
Had that happen on my EJ22. $600 into rebuilding the engine, ran great, but appanently lean on #3 injector. Smoked the cyl and a valve, put a spare head on, smoked that valve too, then figured out it was running lean. one little injector can really ruin a well built motor.
That sucks bad man.
Why those Things Happens? :confused:
...one little injector can really ruin a well built motor.
That sucks bad man.
If that was Due to a Bad Injector, it Really Sucks! :-\
it Means that a Carburetor Never can do that Damage... isn´t it?
Well... Good Luck with the New Asembly! ... Pics Please! :burnout:
Essentially, you are right. That particular problem is something that only a TPI (tuned port injection) system can have.
Steveman, you were the one with the BRAND NEW shortblock ea82T, right?? was that a turbo compression motor, or an NA block? that sucks, man.. to be done in by something STUPID like that....
yeap brand new soa shortblock Ea82T I racked up 20,000miles of pure fun tho :)
I allready swapped the block for another brand new one ;)
oh yeah why not, just shovel some more cash towards it ;)
I think it is great you are willing to spend so much time and money on something you end op blowing up again :lol: j/k
but now more serious, I really do think you are doing a good job, I might have done some things differently but it's the results that count
Steve, what kind of injectors are you running again? I ask because I have a butt-load of 280ZX (mostly NA ZX) injectors that I need to sort through and clean and test, it is a project that has been on my to-do list for a long time... but I havent prioritized it. If you could use some new injectors (IE, double set) I could "get around" to doing this stuff very soon and send you a set out on the cheap.. these are parts I need to move anyhow. PM me if youre at all interested.. I realize that you are likely already running higher flow injectors than what Ive got, but I figured I would offer/mention it.
Anyone who has built a race car knows what I'm going through and no matter how much you prepare for it ************ happens, this failure was due to the #4 Fuel Injector going bad which ran Cylinder #4 LEAN, out of my control. Had the injectors flowed, #4 flowed 53% less fuel than others.
This new shortblock didnt cost me anything since I was able to warranty out another one since I know the parts manager.
I have a brand new set of injectors for it from Venom that are 360cc that I will be installing, the injectors that failed were the 280ZX Turbo Injectors.
Keep in mind I had 20,000miles of hard abusive driving on that block/build and the compression test showed near perfect compression on all other cylinders, so if it wasnt for the injectors the engine would still be running.
BTW Total Project Price 3 motors later and price of buying car = $5000/give or take a few bucks.
5k for a 12-13second car isnt bad.
Amen to ALL of the above, and envy projected over your mad engine block hookups...
Had to ask about the injectors, even though I think i recall reading something elsewhere about your future plans. Good to see that after 20K the block was still in good shape otherwise. More fuel should be good, i bet it evens things out even more than you anticipate.
Hope everything goes back together well.
