SOOBOUTLAW Posted April 11, 2007 Share Posted April 11, 2007 Anybody ever take off the asv spacers on the exhaust ports and put the original header back on? If so, how's the clearance? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted April 11, 2007 Share Posted April 11, 2007 I dont think that will work. The angle of the exhaust will be off where it mounts on the tranny. You would need to either get some spacers or get another Y pipe that is made for use without those spacers. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 11, 2007 Share Posted April 11, 2007 It will hit the engine cross-member. Leave the spacer as it's iron, and you can tap threads for 7/16"x20 into it for a more secure fitment of the flanges. Also cut the threaded end off the ASV pipe and weld it up using a washer, etc. That will effectively block the port on the side of it. GD Quote Link to comment Share on other sites More sharing options...
