Caliper Removal
caliper doesn't need to be removed to replace the pads.
if you do need to remove the caliper, there are two bolts holding the caliper bracket to the back of the hub. remove those two bolts (17 mm on the XT6 and i think the same on the EA82) and the caliper assembly comes off.
Sounds to me like the caliper is locked up. Do you smell brake pads burning (or even better, see smoke coming from the wheel) while driving?
It could be a misadjustment of the parking brake, but most likely, the caliper is seized up and needs replacement.
If that's the case, just remove all the bolts like suggested and go to town on it. Beat it off with a hammer if you must. It's no good to you anymore, so get it off with any means necessary. It can be done, I've removed seized calipers before.
