kamakazisubee Posted April 13, 2007 Share Posted April 13, 2007 Any body know how hard it is to change pan gasket on 86 4x4 n/a 1.8 with the eng in the car? also the best place to get gaskets? thanks JOE:grin: Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 13, 2007 Share Posted April 13, 2007 It's about this hard |----------| Get one from the dealer ONLY. GD Link to comment Share on other sites More sharing options...
Frank B Posted April 13, 2007 Share Posted April 13, 2007 From what I've read here on the board, you'll have to remove the nuts on the engine mounts, and jack up the engine. I think you'll have to remove the pitch stopper on top two. Just take a good look at how it's set(count the turns, etc). Then it's still a pain since there are baffles inside the pan that get hung up on the pick-up tube. But I have never done one so............ Link to comment Share on other sites More sharing options...
Snowman Posted April 14, 2007 Share Posted April 14, 2007 Get one from the dealer ONLY. GD Can I get a hallelujia!! Amen to that! Link to comment Share on other sites More sharing options...
subyrally Posted April 14, 2007 Share Posted April 14, 2007 acording to subaru, at least when i asked, there is no actual gasket for the oil pan. you can buy em aftermarket all day, but i think they used rtv sealant. at least from what a dealer out here and a couple shops told me. eh, always double check if you can. Link to comment Share on other sites More sharing options...
zstalker Posted April 14, 2007 Share Posted April 14, 2007 it looks like there is indeed a gasket for the oil pan for that year (subyrally is right, some years don't use one), and alldata says it's a 2.0 hour job...so it's not going to be *terribly* hard, but it's going to take a while. I would imagine you should pull out the pitching stopper and nuts from the motor mounts (as mentioned above), jack up the motor a couple inches and you can put something under the mounts like blocks of wood or something. something else to think about: these motors are not terribly hard to remove entirely, and if there's anything else to work on, just pull the motor and do it all at once. ~Erik~ Link to comment Share on other sites More sharing options...
Gloyale Posted April 14, 2007 Share Posted April 14, 2007 I think you'll have to remove the pitch stopper on top two. Just take a good look at how it's set(count the turns, etc).[/Quote] OP has not stated whether or not this is an EA81(Brat, Hatch) or an EA82(Wgn, Sdn,Cpe) but as a note, EA82s do not have an adjustable pitching stopper. so no counting required. acording to subaru, at least when i asked, there is no actual gasket for the oil pan. you can buy em aftermarket all day, but i think they used rtv sealant. at least from what a dealer out here and a couple shops told me. This applies to EJs.(legacy,impreza,etc..) EA motors definately use a gasket. It is a different gasket each for EA81 and EA82. these motors are not terribly hard to remove entirely, and if there's anything else to work on, just pull the motor and do it all at once.[/Quote] This is a very good point. If you want to temporarily slow a leaky pan until an engine removal,(for clutch, rear main, HG, whatever else) It ussually helps alot to just tighten the oil pan bolts a bit. just a snugging(1/4 turn), you don't want to distort the pan or strip anything. But the old cork gasket has most likely hardened alot, so a little snugging helps alot. The bolts along the back are blocked by the crossmember, but can be gotten at with extentions and a swivel on your socket wrench, or with a long #3 phillips screwdriver through the small access holes in the crossmember. Link to comment Share on other sites More sharing options...
DerFahrer Posted April 14, 2007 Share Posted April 14, 2007 If it's an EA81, p/n is 11121AA030. If it's an EA82, p/n is 11121AA001. EAs have oil pan gaskets, EJs don't. They're the ones that use silicone/RTV. Yeah, you're gonna have to jack the engine way up. Or remove it. Link to comment Share on other sites More sharing options...
Snowman Posted April 15, 2007 Share Posted April 15, 2007 Yup, the EJ cars don't use a gasket from the factory. You can buy them aftermarket for some reason, but I would put more faith in some Ultra-grey or anaerobic sealant than some cheap piece of crap, errr... cork. The EA cars do use gaskets and they are available from the dealer. Link to comment Share on other sites More sharing options...
