EA82/EA81 Intake thought/Idea
It's been said that the EA82 intake would fit an EA81 car right? If so, that would mean that the EA81 would fit the EA82 then. Sooo, I was thinking, Maybe I should put my dual carbs on my EA82T. What do you think? Do you think this would be better than the spider intake? It would definately be the first. (Unless the guys down under have done it) Give me your thoughts/ideas about this. Boz
i had an ea81 carter/weber intake on my spfi block in my turbo wagon. , but i had to eliminate the egr for it to fit.
with that setup, i had to mahe a dent in the ps reservoir for this little solenoid...
hitachis fit, too. as far as being the right width, and the ports match, it will fit perfectly
if the intake is from an old school ea71, it will be too narrow. but if it goes to an ea81, then for sure it will fit on an ea82
ok first question why carb a turbo motor? And B why why why a turbo motor
and to give you some advise the turbo motors heads are different than the carbed/spfi heads they are "dual port" instead of "single port" sorry my vw past has came back to haunt me LOL so..... just put the spider intake on so you still have the fuel injection and better performance especialy if you put a WRX intercooler on it :drunk::banana:
Well, I just ran downstairs to take a looksy to be sure. My turbo motor is carbed however, It has two "runners". Damn, I wonder if I could duplicate this manifold and install two for dual cabs each with it's own "runner" otherwise, find an spare intake manifold like mine and fab something up so I could use 2 carbs. (Dual webers??)
So, since this is a carbed motor, I guess I really can't use the spider intake afterall, huh?
If I remember I will compare my DC manifold to the one on there and see what is possible.
BTW, My dual carb manifold is for an EA81 for whoever was wondering, Sorry I forgot to mention that.
Thanks for the great imput, Boz
