pamike Posted April 15, 2007 Share Posted April 15, 2007 i thought it was comeing from the top hose but its not. i got a puddle of antifreeze under the intake laying on the top of the motor on the right side. it's running down the front and getting the timing cover wet. where could it be coming from. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted April 15, 2007 Share Posted April 15, 2007 THere's two coolant temp sensors under the intake on the passenger side. One of them could have sprung a leak. Sop up what's on the block, then watch to see where the coolant is coming out. Quote Link to comment Share on other sites More sharing options...
pamike Posted April 15, 2007 Author Share Posted April 15, 2007 its possable the sensor could be leaking because i changed it a while back. but i just wanted to know, is their any kind of seal or gasket that could be leaking. Quote Link to comment Share on other sites More sharing options...
pamike Posted April 20, 2007 Author Share Posted April 20, 2007 on the front top of the engine under the alt. and next to where it says ej22 their is some kind of sensor. it looks wet around and at the wire connection. what is this part. Quote Link to comment Share on other sites More sharing options...
pamike Posted April 21, 2007 Author Share Posted April 21, 2007 i think i may have figured out my problem. i put the top rad hose on the other day and i still had the puddle. i just found out it is oil not coolant. so i think i had 2 leaks. after fixing the hose and still seeing wetness i assumed it was coolant. the sensor below the alt is the oil pressure sensor and i think it's leaking. it is possable for it to break and leak out the top right? do i have to remove the alt to change it and is it a part most auto stores have in stock. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted April 21, 2007 Share Posted April 21, 2007 Not sure if auto parts stores carry that, but it is most likely 1/8" BSPT (british standard pipe tapered thread), so you could plug it temporarily if needed. If the sensor isn't snapped off it might just need to be resealed. Quote Link to comment Share on other sites More sharing options...
