wtdash Posted April 15, 2007 Share Posted April 15, 2007 '90 Legacy 4wd wagon, Auto. Vibration driving @ 65-75, most noticeable in shaking steering wheel. History: 1. Car had soft/bouncy struts, so I put used (60K) Outback struts on all 4 corners. 2. Put on my 15" Studs to fill up the wheel wells, which had a little vibe going on about 70, but nothing like now. 3. Put slightly used (still have nubs) 205/75R14 tires on the OEM wheels and vibration started. Took back to shop to re-balance and they showed me how the wheels are warped - not "true" maybe 1/8" off? Not out of round - but side-to-side. Wheels still balanced OK. Would the wheels cause the vibration? Or are the used tires more likely the cause? The old 185/70R14 didn't vibrate like the new ones...but maybe the soft struts masked it? Thanks Link to comment Share on other sites More sharing options...
OB99W Posted April 15, 2007 Share Posted April 15, 2007 You might find some useful info in one of my previous posts: http://www.ultimatesubaru.org/forum/showpost.php?p=586934 Link to comment Share on other sites More sharing options...
Commuter Posted April 19, 2007 Share Posted April 19, 2007 '90 Legacy 4wd wagon, Auto. Vibration driving @ 65-75, most noticeable in shaking steering wheel. History: 1. Car had soft/bouncy struts, so I put used (60K) Outback struts on all 4 corners. 2. Put on my 15" Studs to fill up the wheel wells, which had a little vibe going on about 70, but nothing like now. 3. Put slightly used (still have nubs) 205/75R14 tires on the OEM wheels and vibration started. Took back to shop to re-balance and they showed me how the wheels are warped - not "true" maybe 1/8" off? Not out of round - but side-to-side. Wheels still balanced OK. Would the wheels cause the vibration? Or are the used tires more likely the cause? The old 185/70R14 didn't vibrate like the new ones...but maybe the soft struts masked it? Thanks Note - Bolding by me. Sure, the wheels will balance, but when rolling along the pavement, the tire will be tracing a slight sine wave instead of a straight line. This causes side to side forces with every revolution of the wheel, which in turn is felt as vibration at the steering wheel. No wheel/tire expert here, but I would consider 1/8" wobble to be quite significant. Commuter Link to comment Share on other sites More sharing options...
wtdash Posted April 19, 2007 Author Share Posted April 19, 2007 I believe it's fixed.....w/new(er) wheels. I bought some used - '96 legacy - wheels off a guy on our local craigslist. Took 'em to a chain - Les Schwab - and they traded me the wheels for the mount/balance. Much better and no wiggle @ the 65-75. the shop said they mount the tires low spot to line-up w/the valve stem..just as one of the articles stated. I didn't check if the old tires were mounted that way. Thanks for the info and the links..... Link to comment Share on other sites More sharing options...
