BIGBLUE1212 Posted April 15, 2007 Share Posted April 15, 2007 Its been 2-3 months since ive had my tranny fluid changed and already the fluid smells terrible. its a auto with 260,000kms or 165,000miles(about). 97 legact gt 2.5 Link to comment Share on other sites More sharing options...
nipper Posted April 15, 2007 Share Posted April 15, 2007 hrmm. Do all your tires match, and are they evenly inflated? Thats the only thing i can come up with, untill something more hidious rears its ugly head. Did you flush the fluid or change just whats in the pan? DO you drive with a heavy foot or with a full load in the car? How are the other fluid levels? nipper Link to comment Share on other sites More sharing options...
BIGBLUE1212 Posted April 15, 2007 Author Share Posted April 15, 2007 The entire system was flushed cause i had some solenoid switches that needed replacing....im not a heavy driver....more towards the easy driver side...and my tires are equally inflated.....all my fluid levels are ok and i try to check them every week along with my tire pressure every week. Link to comment Share on other sites More sharing options...
porcupine73 Posted April 15, 2007 Share Posted April 15, 2007 When you say stinky do you mean significantly different from new ATF? Is it blackish? What brand/type fluid was put in? The most likely reason for stinky/back ATF fluid is overheating, says above 200 deg. F regularly. You could put in an ATF temp gauge if desired. Was the in-radiator cooler flushed too? If it's plugged with shrapnel maybe it's not circulating too well. Link to comment Share on other sites More sharing options...
