oil pump leaking
Oil pump is leaking on my '86 Brat. This is quite common I guess as all my other high mileage Soobs did this. Can I get away with using the old pump and just replacing the gasket or seals? What kind of gaskets or seals will I need?
Thanks
you can just get the "mickey mouse o'ring" and be just fine.
you can get a whole kit, which comes with the mickey mouse, a round o-ring, and a shaft seal. bumps themselves dont generally go bad, bieng a trichoidial design. very simple and not complex
