siouxan Posted April 16, 2007 Share Posted April 16, 2007 Clutch cable snapped and replaced it. now car won't start. help!!! Link to comment Share on other sites More sharing options...
DerFahrer Posted April 17, 2007 Share Posted April 17, 2007 As in won't turn over, or won't even crank? If it won't even crank, did you disconnect the clutch safety switch in the process? If so, you need to plug it back in . The signal to the starter runs straight through that switch, so if that switch isn't plugged in, the starter won't get the signal to operate. Link to comment Share on other sites More sharing options...
