seth3030 Posted April 16, 2007 Share Posted April 16, 2007 so i have been driving it on the freeway and when i push it to get to like 70 or so up hills or even on flat ground it starts to have trouble the power goes away and the engine starts to idel really rough while driving it so i pull over turn it off and start it back up and it was fine. i came out to start it up this morning and it wouldn't start everything turned on but when i went to turn it over nothing happend no sounds or anything. could both these problems be linked or are there two diffrent problems? my guess would be tranny and starter or something like that. any help would be awsome. 1994 legacy L wagon Link to comment Share on other sites More sharing options...
Hodaka Rider Posted April 16, 2007 Share Posted April 16, 2007 More info on car: is it an auto? If so, when was the tranny serviced last? When was the last tuneup (filters, plugs, etc)? Link to comment Share on other sites More sharing options...
ericem Posted April 16, 2007 Share Posted April 16, 2007 Any resitance getting the RPM's up in neutral???? Link to comment Share on other sites More sharing options...
porcupine73 Posted April 16, 2007 Share Posted April 16, 2007 Hm...how about fuel filter or knock sensor for the hestitation/no power problem? Any service lights on? Do you even get a clicking sound when trying to start? How about if you tap the starter with a hammer? Link to comment Share on other sites More sharing options...
seth3030 Posted April 17, 2007 Author Share Posted April 17, 2007 automatic tranny last service was honestly like a year ago.i don't know whe the tranny was last looked at i bought the car in september in nuetral it seems fine. the service lights came on once but only because the car died on the free way it just sputtered then had no power then died. Link to comment Share on other sites More sharing options...
seth3030 Posted April 17, 2007 Author Share Posted April 17, 2007 ok so after a day of sitting i tried to start it and it started i let it warm up then turned it off to see if i could start it and now its doing the same thing again! help please this is getting frustraiting Link to comment Share on other sites More sharing options...
unverviking Posted April 17, 2007 Share Posted April 17, 2007 seth3030 said: so i have been driving it on the freeway and when i push it to get to like 70 or so up hills or even on flat ground it starts to have trouble the power goes away and the engine starts to idel really rough while driving it so i pull over turn it off and start it back up and it was fine. i came out to start it up this morning and it wouldn't start everything turned on but when i went to turn it over nothing happend no sounds or anything. could both these problems be linked or are there two diffrent problems? my guess would be tranny and starter or something like that. any help would be awsome. 1994 legacy L wagon Had a 93 Leg L Wagon, had similar issues, going up a hill lost all kinds of power, then got to flat, same thing. Pulled it over and parked, wouldn't start. Turned over, but no go. In the end found loose spark plugs. May be something to look into. Not sure as to why they loosened up, but they did... Link to comment Share on other sites More sharing options...
seth3030 Posted April 17, 2007 Author Share Posted April 17, 2007 i'll look into it thanks man Link to comment Share on other sites More sharing options...
seth3030 Posted April 17, 2007 Author Share Posted April 17, 2007 they look to be on there good though. i hit the shifter console part after it wouldn't start and it started up fine. lose connections i should look for? or tranny probs? Link to comment Share on other sites More sharing options...
jamal Posted April 17, 2007 Share Posted April 17, 2007 could have something to do with the shift interlock. Also if it flashed the check engine light you can pull the code to see what it is. Directions here: http://www.surrealmirage.com/subaru/engine.html Link to comment Share on other sites More sharing options...
nipper Posted April 17, 2007 Share Posted April 17, 2007 Next time it happens put the car in NEUTRAL and try to start it. If he can move the shift lever, the interlock is fine. It sounds like a bad Neutral Saftey switch on the start. The loss of power is going to be a bit tougher. When was the last time this thing had a tune up ? What condition is the knock sensor in? nipper Link to comment Share on other sites More sharing options...
seth3030 Posted April 17, 2007 Author Share Posted April 17, 2007 i am gonna give it a tune up this weekend and i don't knw where or what a knock sensor is. i have been able to start it up now fine every time. i just hit the shifter console and it has been starting up ever since. when it was turned off and in park i couldn't move it into nuetral. i tried that to see if it would make a difference but i couldn't move it. Link to comment Share on other sites More sharing options...
nipper Posted April 17, 2007 Share Posted April 17, 2007 seth3030 said: i am gonna give it a tune up this weekend and i don't knw where or what a knock sensor is. i have been able to start it up now fine every time. i just hit the shifter console and it has been starting up ever since. when it was turned off and in park i couldn't move it into nuetral. i tried that to see if it would make a difference but i couldn't move it. Ok that clarifies things. You have bad/sticky interlock. I bet that one time it was jammed. Learn how to bypass the interlock just in case it happens again. If you do a search here, try the word interlock, you should be able to find it covered in some detail. nipper Link to comment Share on other sites More sharing options...
seth3030 Posted April 18, 2007 Author Share Posted April 18, 2007 but does that explain the engine going crazy at 70 mph? and rough idle when driving? Link to comment Share on other sites More sharing options...
nipper Posted April 18, 2007 Share Posted April 18, 2007 seth3030 said: but does that explain the engine going crazy at 70 mph? and rough idle when driving? One thing at a time. define going crazy at 70mph. How many miles on this car. When was the last time it had a tuneup Have you pulled the codes yet? nipper Link to comment Share on other sites More sharing options...
seth3030 Posted April 18, 2007 Author Share Posted April 18, 2007 the engine starts sputtering and the rpm gauge starts jumping around like its barley trying to run so i pull over. it has around 127k on it. i am gonna give it a tune up this weekend what should it include(fuel filter, spark plugs, air filter oil change and what else?). what do you mean by pulled the codes? i don't think i have. Link to comment Share on other sites More sharing options...
nipper Posted April 18, 2007 Share Posted April 18, 2007 seth3030 said: the engine starts sputtering and the rpm gauge starts jumping around like its barley trying to run so i pull over. it has around 127k on it. i am gonna give it a tune up this weekend what should it include(fuel filter, spark plugs, air filter oil change and what else?). what do you mean by pulled the codes? i don't think i have. So your not reading the responses to your own post http://www.surrealmirage.com/subaru/engine.html Thats from jamal pull the codes from the car computer. Also replace the ignition wires with OE wires. nipper Link to comment Share on other sites More sharing options...
Cougar Posted April 20, 2007 Share Posted April 20, 2007 I suspect the problem you are having at high speed is due to a fuel delivery problem. If changing the filter doesn't help with this then I would check the fuel pressure to see if a weak pump is causing the trouble. Link to comment Share on other sites More sharing options...
Gloyale Posted April 20, 2007 Share Posted April 20, 2007 seth3030 said: the engine starts sputtering and the rpm gauge starts jumping around like its barley trying to run so i pull over. it has around 127k on it. i am gonna give it a tune up this weekend what should it include(fuel filter, spark plugs, air filter oil change and what else?). what do you mean by pulled the codes? i don't think i have. Definately change the plug wires as well. They should really be changed every 20-30k miles. Yet most cars with 100-150K miles still have their original wires. My 93 Legacy ran like crap, stalling and sputtering, for awhile a few years ago. Mom was ready to sell it(this was before I bought it from her). We changed the plug wires and VROOOM! Also it's a good idea to change the O2 sensor. Also is anyone else thinking maybe his t-belt or tensioner could be loose/skipping? Big loss of power there Link to comment Share on other sites More sharing options...
