Dickensheets Posted April 18, 2007 Share Posted April 18, 2007 Any recommendations? Cleaning up the front brakes tomorrow. rd Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 18, 2007 Share Posted April 18, 2007 see below... Quote Link to comment Share on other sites More sharing options...
Strakes Posted April 18, 2007 Share Posted April 18, 2007 I have used AGS Sil-Glyde Brake Lubricant. Works great. http://www.agscompany.com/products/index.php?catId=53&viewProducts=true Quote Link to comment Share on other sites More sharing options...
nipper Posted April 18, 2007 Share Posted April 18, 2007 Brake lube like said above. nipper Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted April 18, 2007 Share Posted April 18, 2007 I used the little red packs of niglube that came with the oem pads for the rears and permatex high temp silicone lube for the fronts from amazon. Trying to see which holds up better. I've heard others say on nasioc that Neo HP 800 wheel bearing grease is 'da bomb as a replacement for the molykote (but not necessarily for the red niglube). I got a pound can in a couple days from stockcarproducts.com Others were saying to buy from bakerprecision.com which I did order from a couple months ago but I never received anything and they didn't return my phone calls. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 18, 2007 Share Posted April 18, 2007 what's the difference between this brake lube and wheel bearing grease for the slides? didn't see anything mentioned on the link. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted April 18, 2007 Share Posted April 18, 2007 I'm not completely sure, but I think the niglube and related lubes are 'compatible' with brake fluid, since it's also used inside the piston boot. The molykote and others maybe aren't great in brake fluid contact but can take heat and pressure better? Not sure... Quote Link to comment Share on other sites More sharing options...
nipper Posted April 18, 2007 Share Posted April 18, 2007 http://www.aa1car.com/library/2005/ic80560.htm thats the difference. nipper Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 18, 2007 Share Posted April 18, 2007 sweet, makes sense. i edited my first post. that explains why there always seems like less when i go back in there the next time! Quote Link to comment Share on other sites More sharing options...
