2flat4s Posted April 21, 2007 Share Posted April 21, 2007 My 89 wagon is stuck in 4x4, and nothing seems to work... I've tried lifting various wheels to relieve driveline tension, and backing up, changing the switch repeatedly, etc... to no avail... It is a push button, part time 4wd, and has only been stuck since yesterday... any help would be greatly appreciated... Thanks! Link to comment Share on other sites More sharing options...
zyewdall Posted April 21, 2007 Share Posted April 21, 2007 Did you check the vaccuum actuator to see if it's actually moving? Perhaps one of the vaccum hoses came off or has a leak. Z Link to comment Share on other sites More sharing options...
msteel Posted April 22, 2007 Share Posted April 22, 2007 My 89 wagon is stuck in 4x4, and nothing seems to work... I've tried lifting various wheels to relieve driveline tension, and backing up, changing the switch repeatedly, etc... to no avail... It is a push button, part time 4wd, and has only been stuck since yesterday... any help would be greatly appreciated... Thanks! Yeah, probably a vacuum issue. Look next to the driver side strut tower at the 4wd vacuum solenoids for loose or broken vacuum fittings. Link to comment Share on other sites More sharing options...
mdjdc Posted April 23, 2007 Share Posted April 23, 2007 If all else fails, you can manually take it out of 4wd by getting under the passenger side of the car and pushing the actuator to the 2wd setting. The system for those cars is a vaccuum actuator that pushes or pulls a cable which puts into or out of 4wd. Follow the cable and you will see the mechanism you have to switch. If my vaccuum ever goes out I will just hook up a cable like the old choke cables to put in in or out of 4wd. Good luck Link to comment Share on other sites More sharing options...
Skip Posted April 23, 2007 Share Posted April 23, 2007 By chance is the heater control system stuck in one mode? The white cyl.on the shelf behind the pass strut is the vac. res. for both systems. Possibly the line to it has been dislodged. Link to comment Share on other sites More sharing options...
