Tsuriman Posted April 22, 2007 Share Posted April 22, 2007 I cant for the life of me figure out where one of the coolant lines coming off the IAC connects to. If you're looking at the IAC from the pass side of the car there is the large air hose in the center, a short "S" shaped coolant line going to the throttle body on the left and the @5-6" "C" shaped line coming off the right side. I cannot figure out where that right side "C" shaped hose connects to. I wouldnt ask if I hadnt spent the last hour looking. TIA Ryan 97 Outback Legacy, 2.5l Link to comment Share on other sites More sharing options...
Tsuriman Posted April 23, 2007 Author Share Posted April 23, 2007 I cant for the life of me figure out where one of the coolant lines coming off the IAC connects to.If you're looking at the IAC from the pass side of the car there is the large air hose in the center, a short "S" shaped coolant line going to the throttle body on the left and the @5-6" "C" shaped line coming off the right side. I cannot figure out where that right side "C" shaped hose connects to. I wouldnt ask if I hadnt spent the last hour looking. 97 Outback Legacy, 2.5l Well I figured it out. I was just a dumb rump roast that couldnt figure it out and well I had a coolant line in the wrong place. So if anyone searches and finds this thread. The "C" shaped hose of the IAC connects to the main coolant rail between the intake and block, the same that the upper rad hose connects to. Tsuriman Link to comment Share on other sites More sharing options...
Olnick Posted April 23, 2007 Share Posted April 23, 2007 No shame, Tsuriman. You solved the problem and were thoughtful enough to post the solution. Thanks! Link to comment Share on other sites More sharing options...
